Combining PIMP in TSMC
Potatoze
Newbie level 6
Hello.
I want to know what is the purpose of the PIMP for PMOS in TSMC. If I connect the PIMP of two PMOS, will there be any problem?
Thanks.
I guess it's the P (usually phosphor) IMPlant for the source and drain regions of the PMOS.
They will get an inside P+ implant for their connections, probably the same P+ implant is used for the substrate contacts, which in this case are to be connected to the most negative voltage of the power supply (GND).
In each case all of them are to be connected.
PIMP is p+ implant.
Eric, Phosphorus is n-type dopant, not p-type.
P-type is Boron and Indium.
Connecting PIMP shapes of two MOSFETs would have the same effect as connecting MOSFET's terminals in the schematic - that may be fine or forbidden, depending on the design specifics.
Ah yes, you're right Max, thank you!
Mixed it up - Phosphor's chemical sign seduced me, probably.
P+ regions are patterned as PIMP*active. The active "hard mask"
would have to connect the two PMOS also, to get an electrical
connection across NWell.
You are right, my statement concerning electrical connection of PIMP shapes was not correct.
It is when "PIMP AND ACTIVE" overlap, (DC) electrical connection happens.
