Results 1 to 2 of 2
    Newbie level 1
    Points: 14, Level: 1
    Sep 2018
    14
    Why DDR3\4, DM is not used in READ operation? I can see how its works on Write but no
    Why DDR3\4, DM is not used in READ operation? I can see how its works on Write but not on read.
    •   AltAdvertisment
    Advanced Member level 3
    Points: 6,670, Level: 19
    Jul 2010
    Sweden
    862
    6,670
    19
    Re: Why DDR3\4, DM is not used in READ operation? I can see how its works on Write bu
    For read operations, it isn't a problem to read the full memory width. The reading device can use whatever bytes it wants.
    For write operations, only the affected bytes can be written, otherwise the other bytes would be corrupted.
    This means that the DM signals are only needed for write operations.
    If the full memory width is used for all write operations, the DM signals are not needed.
