[SOLVED] About RF circulator in pcb design
yuyee
Junior Member level 2
Pardon me for having many questions.
Please give some comments/suggestions to enlighten me.
1) In the RF circulator datasheet, I saw "forward power and reverse power", can anyone explain what is that about?
2) what are the things that need to know when using circulator?
3) Does a circulator require 50ohm matching for all ports? In what way we can achieve 50ohms? what will happen if I did not achieve 50ohms?
4) signal flowing from Port 1 will flow to Port 2, and signal from Port 2 will flow to Port 3. Does the signal from port 3 will flow to Port 1? By right based on board design, signal shouldn't flow from port 3 to port 1.
Best Regards,
yuyee
hi yuyee,
1)forward power is the max power handling capacity from port 1 to port 2. reverse power is the max power from port 2 to port 3.
2)take notes on s parameter and power capacity.
3)port 3 require 50 ohm matching.
4)singal will flow from port 3 to port 1. in this case, you can imagine port 3 as port 1, port 1 as port 2.
hi yuyee,
Noted with thanks.
Does anyone know how a 50 ohms matching can be done?
Let say Port #2 is an input port, will there be signal out from Port 2 and flow into Port 3 ?
Thanks & Best Regards,
yuyee
Yes, reflection from the load at port 3 will go to port 1. Signal flow in the circulator is shown by the arrows in your picture.
Yes, if your input port is not perfectly matched.
You can get better support if you describe your application for the circulator.
Noted thanks.
What will affect the application of each port when 50 ohms is not match?
Can someone advice me how to match 50 ohm? Thanks
yuyee
You are asking the wrong questions and perhaps don't understand the use of a circulator.
1) The signal flow is indicated by the arrows.
2) You want your TX signal to go to the antenna, and the received antenna signal to the RX. That is the left option in your picture.
3) If your antenna is not well matched, some of the TX signal is reflected inside the antenna and now goes to the RX. If that is your problem, you need a better antenna match. That is specific to the antenna, there is no simple 1 minute rule how to do that.
Noted thanks.
yuyee
Just some comment in addition to volker@muehlhaus. volker@muehlhaus is right, if your port to antenna is not perfectly matched, there will be reflection. The reflection will routed to RX port. If your signal is of narrow band, usually it is not difficult to design the impedance matching network.
Another device you may consider to use is directional coupler.
To do what? Don't confuse him, the circulator does a better job for this task.
Yes, circulator is better for TX/RX antenna multiplexing. But if you could accept the loss, directional coupler is ok as well. Directional coupler is much cheaper and easier to get than circulator.
Generally the goal of impedance matching is to transfer the greatest amount of power(W=V* A). Suppose your incoming signal is high V, low A. This implies high impedance. Then suppose your next stage wants a signal which is low V, high A. This implies low impedance. To maximize power transfer, an impedance matching network is installed. Often it consists of a transformer, or combination of inductors and capacitors.
For instance, at one time public address systems had a 70V output (at weak Amperes). It could be called high impedance.
The audio signal was wired to several speakers. Audio speakers are commonly 8 ohms (low impedance). A signal of 1 or 2 volts is needed to drive it loud enough so a roomful of people can hear it.
Each speaker-box had a 70V transformer inside, which stepped down the voltage (thus stepping up the current). Thus the system matched a high impedance in the PA amplifer, to low impedance in the speaker boxes.
Thanks everyone. Does anyone know whether the circulator can place near to a SMA/metal/magnetic kind of material ?
If the circulator has a metal shield, you can place it at anywhere.
