Results 1 to 6 of 6
    Full Member level 3
    Points: 953, Level: 7
    Apr 2017
    152
    953
    7
    Installing HFSS on Centos 6.4
    I am trying to install HFSS 17.2 trial on Centos 6.4.
    I launch the ./INSTALL file and get the following errors, see attached.
    Is there anything I can do to fix this ?
    Thank you.
    •   AltAdvertisment
    Points: 27,514, Level: 40
    BigBoss's Avatar
    Nov 2001
    Turkey
    3,963
    27,514
    40
    Re: Installing HFSS on Centos 6.4
    I think it requests Administrator right..( just a thought)
    •   AltAdvertisment
    Full Member level 3
    Apr 2017
    152
    953
    7
    I am new to Centos 6.4, so I dont know how to run things as Administrator - how would I do that ?
    I am running the files as root user - isnt that administrator ?
    Thank you.
    •   AltAdvertisment
    Points: 48,823, Level: 53
    Apr 2011
    Minneapolis, Minnesota, USA
    12,143
    48,823
    53
    As a way to make sure, right-click on the program. Look for an option "Run as Administrator".
    I've seen this in Win 7. I can't verify for other environments.
    Administrator is a level you select when creating an account. It allows greater privileges compared to an ordinary user.
    Advanced Member level 3
    Points: 6,301, Level: 18
    Jun 2012
    Edmonton, Canada
    978
    6,301
    18
    Quote Originally Posted by Puppet123 View Post
    Use the sudo command?
    •   AltAdvertisment
    BigBoss's Avatar
    Nov 2001
    Turkey
    3,963
    27,514
    40
    Thank you.
    Type "su" then enter password then run the installer as administrator.
    Or
    Type "sudo <installation script/program> then password ..it will run.
