Installing HFSS on Centos 6.4
Puppet123
Full Member level 6
I am trying to install HFSS 17.2 trial on Centos 6.4.
I launch the ./INSTALL file and get the following errors, see attached.
Is there anything I can do to fix this ?
Thank you.
I think it requests Administrator right..( just a thought)
I am new to Centos 6.4, so I dont know how to run things as Administrator - how would I do that ?
I am running the files as root user - isnt that administrator ?
Thank you.
As a way to make sure, right-click on the program. Look for an option "Run as Administrator".
I've seen this in Win 7. I can't verify for other environments.
Administrator is a level you select when creating an account. It allows greater privileges compared to an ordinary user.
Thank you.
Type "su" then enter password then run the installer as administrator.
Or
Type "sudo <installation script/program> then password ..it will run.
