Results 1 to 3 of 3
    Points: 744, Level: 5
    Dec 2014
    coimbatore,tamil nadu,india
    7
    744
    Discrete power Supply Circuit Working
    I need a transformer-less power supply circuit to power my PIC microcontroller. I came across the following circuit from here
    http://ww1.microchip.com/downloads/e...tes/40171a.pdf
    It converts 120V AC to 5V DC (or that's what I understand). I can make out that zener is used as regulator but still cannot get a clear picture
    Can some one please explain how this circuit works and how I can modify it to convert 220V AC to 5V DC. Also how to calculate the current it can source?
    •   AltAdvertisment
    Points: 72,643, Level: 65
    Apr 2014
    14,783
    72,643
    65
    Re: Discrete power Supply Circuit Working
    do a search for "transformerless supply".
    In short:
    The key is: C3 forms a capacitive impedance for current limiting. Xc = 1 / ( 2 x Pi x f x C)
    If you have about twice the input voltage, then you need about twice the impedance for the same current.
    --> Choose half of the initial capacitor value.
    But you don´t talk about
    * mains frequency (see formula above "f" )
    * load current
    Maybe it´s easier for you that C3 is replaced by a resistor with the value "Xc".
    You won´t use the resistor in reality, because it will generate a lot of heat.
    The benefit of the capacitor is that it doesn´t generate heat. It doesn´t waste true power.
    •   AltAdvertisment
    Points: 51,231, Level: 55
    Apr 2011
    Minneapolis, Minnesota, USA
    12,575
    51,231
    55
    The capacitive drop method is an inexpensive supply which gives a few mA at low voltage. It is non-isolated, so if it fails it may expose your expensive equipment to 220 VA, directly or indirectly.
    To find capacitive impedance here is the standard formula. Use it to get an approximate figure.
    XC = 1 / (2 Pi f C)
    Your schematic has 0.1 uF.
    At 50 Hz it might provide one or two mA.
