Results 1 to 6 of 6
    Full Member level 3
    Points: 2,464, Level: 11
    Apr 2009
    183
    2,464
    11
    [Help] Feed network layout for 8x8 dual polarized planar microstrip stacked antenna
    Dear Members
    Good day to you all.
    I have designed a multilayer stacked antenna comprising of dual polarized ports. Next step in my design is to make an array of 8x8 elements. For this array I am thinking of using Wilkinson power divider as a feed network, but unfortunately the feed network layout is not easy to come by.
    Can anyone suggest any good paper to start working on or some other feed network options for the 8x8 dual polarized design.
    Looking forward to your replies,
    Best Regards
    •   AltAdvertisment
    Advanced Member level 3
    Points: 6,383, Level: 19
    Jun 2012
    Edmonton, Canada
    994
    6,383
    19
    Re: [Help] Feed network layout for 8x8 dual polarized planar microstrip stacked anten
    I think generally a WPD for antenna feeding networks is overkill. You are essentially guaranteed the antenna port impedances are constant (unless you for some reason have unreasonably sized patches for a very low operating frequency); so isolation isn't really needed.
    Standard T-junctions work well in practice. There are many such layouts in the literature.
    Good Luck!
    •   AltAdvertisment
    Full Member level 3
    Apr 2009
    183
    2,464
    11
    @PlanarMetamaterials
    Thank you for ur suggestion, Can you recommend some papers that present the 8x8 layout either with WPD or T-junctions.
    My center freq is at 28 GHz and I am using micro strip aperture coupled technique.
    •   AltAdvertisment
    Jun 2012
    Edmonton, Canada
    994
    6,383
    19
    Googling "T-junction aperture patch array" yields some good results.
    Check out "Wideband Aperture Coupled Patch Array Antennas — High Gain, Low Side Lobe Design", Dhruva Poduval and Mohammod Ali, Progress In Electromagnetics Research, Vol. 160, 71–87, 2017
    Covers a 4x4 array of aperture-coupled patches.
    Full Member level 3
    Apr 2009
    183
    2,464
    11
    I will look for the designs. If I am unable to find, Iwill ask for ur assistance.
    •   AltAdvertisment
    Full Member level 3
    Apr 2009
    183
    2,464
    11
    I read there paper availble on PIERS, good work by team.
    But Im mostly interested in dual polarized aperture coupled patch array feed comprising of 8x8 elements or even 4x4 to get an idea...
    Any good papers in mind.?
