Results 1 to 6 of 6
    Full Member level 3
    Points: 3,564, Level: 14
    Oveis.Gharan's Avatar
    Oct 2006
    Iran
    188
    3,564
    14
    How to Extract 24 bits per pixel image from YUV422 (CCIR565)?
    Hi everybody
    I want to grabb digital 24 bit per pixel video from PAL format analog video. I find the PAL video decoder TW9912 from Intersil that could decode analog PAL video to CCIR565 YUV422 digital video stream. How could i grab the 24 bit per pixel image from this digital video stream.
    Thanks in advance.
    Oveis
    •   AltAdvertisment
    Points: 8,793, Level: 22
    Easyrider83's Avatar
    Oct 2011
    Tallinn, Estonia
    1,558
    8,793
    22
    Re: How to Extract 24 bits per pixel image from YUV422 (CCIR565)?
    I2c for configure and ITU-R 656 for video stream
    Love me or hate me. All infractions will be ignored.
    •   AltAdvertisment
    Full Member level 3
    Oct 2006
    Iran
    188
    3,564
    14
    Quote Originally Posted by Easyrider83 View Post
    Do you mean that Analog Video Decoders such TW9912 could be configured to be YUV420 instead of YUV422?!
    •   AltAdvertisment
    Points: 38,027, Level: 47
    Mar 2008
    USA
    6,143
    38,027
    47
    Have you looked at commercially available "frame grabbers"
    purporting to handle at-speed video, to see
    1) which ones produce 24-bit video capture at video rate
    2) of those, what's the guts?
    Probably a HD or better stream will be difficult to throw
    across any distance without heavy compression (another
    stage of processing). Where will you put the data, is a
    point to ponder. But PAL (as my decades-stale understanding
    lies) is low resolution and low frame rate). On the minus
    side, PAL and NTSC are pretty poor Z resolution as well,
    as they are analog fundamentally and so prone to SNR
    degradation from many sources. That being the case, do
    you expect true chroma channel ENOB=8?
    Full Member level 3
    Oct 2006
    Iran
    188
    3,564
    14
    Quote Originally Posted by dick_freebird View Post
    Do you mean that the PAL Video Decoding with 24 bits per pixel is not meaningful at all?
    •   AltAdvertisment
    Mar 2008
    USA
    6,143
    38,027
    47
    No, I mean that expecting 8 bits of fidelity is probably
    going to end in some disappointment (if you were to
    measure; as video, you probably get out what you put
    in and maybe that's enough).
    But 24 bpp when the video quality only deserved 5+6+5
    just makes all of your hardware chain that much more
    challenging, for what upside?
