Results 1 to 13 of 13
    Member level 3
    Points: 1,666, Level: 9
    Feb 2011
    64
    1,666
    9
    I don't understand impedance matching of the RF circuit in the schematic
    Ok, refer to attached schematic I drew, I do not quite understand why the design is like this, I have below doubts:
    1. are the caps and inductors for the purpose of impedance matching? If yes, is it still necessary to design the 50 ohm impedance trace at indicated location?
    2. What is the difference of LC impedance matching and 50 ohm trace design impedance matching?
    3. is the impedance matching for signal integrity or max power efficiency, or for both?
    4. The BAW filter will change electrical signal to acoustic signal, what is the purpose of such conversion? And how to realize narrow bandpass fitering with BAW?
    5. If all the traces are very short, e.g less then 1cm, still need impedance matching or not?
    Sorry I asked a lot of questions, but I am very curious about RF knowledge.
    Points: 13,923, Level: 28
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,088
    13,923
    28
    Re: I don't understand impedance matching of the RF circuit in the schematic
    Quote Originally Posted by simbaliya View Post
    Yes.
    BAW requires 50ohm terminations at both sides.
    What do you mean by "50 ohm trace design impedance matching" ?
    If you mean "signal integrity" as spurious emission, for both.
    To make small filter.
    Consider wavelength of 1GHz as both electrical and acoustic signals.
    Latter is very short.
    Rather broadband is difficult.
    Still need impedance matching, since BAW requires 50ohm terminations at both sides.
    •   AltAdvertisment
    Member level 3
    Feb 2011
    64
    1,666
    9
    Quote Originally Posted by pancho_hideboo View Post
    Yes.
    Hi, Thanks for the quick reply, what I mean by 50 ohm trace design is to design a 50 ohm characteristic impedance trace in the PCB for that rf signal, in which the PCB stack up, PCB trace width, and some other factors are considered.
    Oct 2006
    Real Homeless
    2,088
    13,923
    28
    If line length is enough short, e.g, less than λ/10, 50 ohm characteristic impedance line is not required.
    Completely different.
    Former has no direct relation to characteristics impedance.
    Points: 11,298, Level: 25
    Apr 2014
    1,784
    11,298
    25
    However, the BAW itself is usually not matched to 50 Ohm. The 50 Ohm are obtained by BAW + matching components.
    This means that internal 50 Ohm line between BAW and matching components is not correct anyway, the interface to 50 Ohm is outside the [BAW + matching] block.
    What frequency? Impedance controlled transmission lines have an effect when the line length is > 1/10 wavelength. Wavelength must be calculated including the substrate influence, so it is smaller than wavelength in air.
    Member level 3
    Feb 2011
    64
    1,666
    9
    Quote Originally Posted by volker@muehlhaus View Post
    What frequency? Impdenace controlled transmission lines have an effect when the line length is > 1/10 wavelength. Wavelength must be calculated including the substrate influence.
    Hi Volker, thanks a lot for the explanation. So now I understand BAW's RX/TX and Antenna port is not designed to have 50 ohm impedance, thus needs external matching elements(caps and inductors) to achieve so. But if I say the signal line is less than 1cm, signal frequency is 2.4GHz, so we do not need LC match for BAW's I/O ports, as well as PCB trace characteristic impedance design, is this true?
    Or still need because even though signal integrity is not a problem, but we need to maximize the power efficiency, both LC elements and PCB trace design are needed even signal line is very short?
    Hope you can explain, thank you!
    •   AltAdvertisment
  7. #7
    Oct 2006
    Real Homeless
    2,088
    13,923
    28
    Your BAW is not same as this thread.
    No.
    Your BAW has to be terminated by 50ohm//Lp1 and 50ohm+Ls4.
    No.
    If we adopt your BAW for figure in start of this thread, BAW means including Lp1 and Ls4.
    What frequency?
    Operation frequency.
    You can not understand BAW at all.
    Volker's explanations are completely wrong.
    BAW requires correct termination.
    In your case, 50ohm at both sides.
    Need LC match for BAW's I/O ports.
    LC elements are required.
    50ohm impedance line is not required.
    Consider case of a direct connection to 50ohm-Antenna without BAW.
  8. #8
    Apr 2014
    1,784
    11,298
    25
    Of course, sweetheart. You are the only true expert. Good luck!
  9. #9
    Member level 3
    Feb 2011
    64
    1,666
    9
    Hi Volker, I want to hear fro different opinions, I would admit I understand your explanation more then the other one, can you help to reply on my previous question? Thank you so much!
  10. #10
    Apr 2014
    1,784
    11,298
    25
    Ask @pancho_hideboo for an answer.
    He is behaving like that in all his threads.
    •   AltAdvertisment
  11. #11
    Member level 3
    Feb 2011
    64
    1,666
    9
    Please, I need your help, try to listen to me instead of him, I really hope I can find answers based on scientific truth.
  12. #12
    Member level 4
    Points: 390, Level: 4
    Jun 2018
    72
    390
    I'm no RF/uWave expert like some of the people here, but pancho needs to learn some manners. Being this rude all the time to everyone is not sustainable.
  13. #13
    Junior Member level 3
    Points: 197, Level: 2
    Aug 2018
    31
    197
    I would think both pancho_hideboo and volker@muehlhaus are nice guys. It is also good to have some disputations. It is the purpose to have this forum. Of course personal insult should be avoided.
    BAW is a very narrow band passband filter and usually needs external impedance matching network to have 50 Ohm impedance at both ports. To have 50 Ohm impedance is to make the connection with other components easier. In your case, your transmitter and antenna are both 50 Ohm, you then of course would like the inserted filter to have 50 Ohm input/output impedance. This will lead to the maxim transducer power gain.
    About the transmission line impedance control. For long line, no doubt the impedance must be strictly controlled. But special care is still needed even for short track. As a rule of thumb, a short thin track can be regarded as small parasite inductor in series, a short but fat track (for example a component pad) can be modeled as a parasite shunt capacitor. The shorter the track, the less parasite effect. So in your case, you should place the impedance matching L/C as close to BAW as possible in layout. Then use strictly impedance controlled track to get connection with TX and antenna.
