anotherbrick
Full Member level 4
- Joined
- Jan 10, 2009
- Messages
- 217
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- Istanbul , Turkey
- Activity points
- 3,142
hello dear forum,
I am trying to amplify the difference of a 100 KHz signal signal from 2 identical coils
( I am trying to build a metal dedector - when metal enters the 1st coils inner , one of the signal wil be stronger and the difference will be amplified by the OPAMP circuit - thats the idea - OPAMP is AD8065 high speed amplifier
the diferential amplifier is the standart difference amplifier circuit from every common application manual - gain is 5x )
as you can see in the osciloscope picture the white signal is the output of differential OPAMP amplifier )
the yellow signal is the AC component of the 12 VDC linear power supply powering the OPAMP
as you can notice there is a 50 Hz noise coming from power supply amplified by the OPAMP
it is about 20 mV - I dont want this noise
my question is how can I eliminate this noise from my OPAMP output
thank you
thank you
