FIFO Memory [Avalon-MM Write Slave to MM Read Slave]: How to read data from FIFO
AbinayaSivam
I want to write 32-bit data into FIFO and read the data from FIFO. So, I have followed this FIFO configuration :Aalon-MM write slave to Avalon-MM read slave.
Questions to be clarified:
1. I have enabled "backpressure" how to set in wait request signal in NIOS (0`s (deserted) or 1`s (asserted)).
2. I want example code to read the data from FIFO. I have tried but its throwing error. "FIFO_0_IN_BASE" is undeclared.
in which file i can find Base address and control address for read operation. Please anyone guide me.
NIOS Code
#include "sys/alt_stdio.h"
#include "alt_types.h"
#include<io.h>
#include<system.h>
#include<stdio.h>
#include "altera_avalon_pio_regs.h"
#include "altera_avalon_fifo.h"
#include "altera_avalon_fifo_util.h"
#include "altera_avalon_fifo_regs.h"
#define FIFO_0_IN_BASE 0x3000
#define ctrl_address 0x3040
int main()
    	int result,i=0;
        int *data=0;
    	IOWR(ENABLE_BASE, 0, 0x1);		// Enable the counter
    	alt_printf("Hello from Nios II!\n");		// Send Hello World to the JTAG UART
    	while(1)
    	//*data = IORD_ALTERA_AVALON_FIFO_DATA(FIFO_0_IN_BASE);
    	data=altera_avalon_read_fifo(FIFO_0_IN_BASE, ctrl_address, 0);
    	printf("%d\n",*data);
    	altera_avalon_read_fifo(FIFO_0_IN_CSR_BASE, ctrl_address,  *data);
    	printf("LEVEL: %u\n", level);
    	while(1)
    	result=IORD(FIFO_0_IN_BASE, 0);
    	printf("%d\n",result);
    for (i=0;i<100;i++)
              result=IORD(COUNTER_OUT_BASE, 0);
    		  printf("%d\n",(result+i));
    	return 0;
WHICH Read function I should Use ? Difference please
Qsys
