Page 1 of 2 1 2 LastLast
Results 1 to 20 of 21
    Full Member level 3
    Points: 1,564, Level: 9
    Jun 2014
    158
    1,564
    9
    FPGA Operating system
    What are the difficulties of producing an operating system for a FPGA? Because from the few I have heard there is nothing made about that, or it can be as a PhD program..
    •   AltAdvertisment
    Points: 7,813, Level: 21
    Apr 2016
    1,646
    7,813
    21
    Re: FPGA Operating system
    Quote Originally Posted by adwnis123 View Post
    ... the whole question makes no sense as posed, as an OS runs on a processor, not on a programmable fabric.
    Really, I am not Sam.
    Points: 37,347, Level: 47
    Jun 2010
    6,792
    37,347
    47
    Linux runs just fine on an FPGA, if the processor is programmed with a CPU.
    Full Member level 3
    Jun 2014
    158
    1,564
    9
    Quote Originally Posted by TrickyDicky View Post
    You talk about OpenSparc?
    Points: 12,974, Level: 27
    Aug 2011
    2,595
    12,974
    27
    It seems that you lack a basic understanding of what an FPGA actually is...
    It's like asking what are the difficulties in an operating system for NAND and NOR gates...
    After watching these:
    https://www.youtube.com/watch?v=CfmlsDW3Z4c
    You'll immediately see how little sense your question has.
    Jun 2010
    6,792
    37,347
    47
    No
    More like NIOS, MicroBlaze, PicoBlaze
  7. #7
    Apr 2016
    1,646
    7,813
    21
    Linux runs just fine on an FPGA, if the FABRIC is programmed with a CPU.
    fixed that for you
  8. #8
    Full Member level 1
    Points: 820, Level: 6
    Dec 2017
    Bydgoszcz - Poland
    102
    820
    Linux can run also on soft-processor like Xilinx Microblze or Altera NIOSII.
    Te question is too general in my humble opinion.
  9. #9
    Advanced Member level 2
    Points: 4,730, Level: 16
    Feb 2014
    638
    4,730
    16
    There are hybrid parts with CPU+FPGA as well such as the Zinq and its counterparts from Altera.
  10. #10
    Jun 2010
    6,792
    37,347
    47
    Quote Originally Posted by FlyingDutch View Post
    Is there an Echo in here? (look at post #6)
    •   AltAdvertisment
  11. #11
    Full Member level 1
    Dec 2017
    Bydgoszcz - Poland
    102
    820
    No
    PicoBlaze has not enough resources to run OS - especially program ROM (form 1K to 4K words - Picoblaze instruction is 18 bit long) and RAM. Second issue with Picoblaze is lack of working properly C compiler (praktically one can use only Picoblaze assembler) - in contex of runnig OS on it.
    No
    why "No" as far as I know someone can run "Solaris OS" on "OpenSparc" soft-processor.
    See project site:
    http://www.oracle.com/technetwork/sy...arc/index.html
    Sorry - I didn't notice your post when answering.
  12. #12
    Full Member level 3
    Jun 2014
    158
    1,564
    9
    Can I run Kali linux on an FPGA, or at least program the FPGA to run commands and run thee Kali linux on a hdd? connected to the FPGA?
  13. #13
    Feb 2014
    638
    4,730
    16
    I think you're still not getting it.
    An FPGA can 'be' anything. One thing it can be is a full fledged 32-bit processor and a 32-bit processors can run linux.
  14. #14
    Full Member level 3
    Jun 2014
    158
    1,564
    9
    Ok, because I do not have the appropriate knowledge on this, can a Xilinx Spartan 3E be used for this? Should I use other any other FPGA model?
    Thank you...
  15. #15
    Jun 2010
    6,792
    37,347
    47
    Thank you...
    Why do you want to do this on an FPGA. You could probably do far more, much more quickly, with a $30 raspberry pi
  16. #16
    Full Member level 3
    Jun 2014
    158
    1,564
    9
    Because as I know (correct me if I am wrong) FPGAs are far more fast than Raspberies..
  17. #17
    Jun 2010
    6,792
    37,347
    47
    It depends on the FPGA.
    The top end FPGAs (with embedded arms or Intel CPUS) will probably run Linux pretty fast. But they will cost you $5000+. And you're not running Linux on the FPGA, you're running it on the embedded Arm/Intel core that is hard IP (Ie. not made of FPGA logic). The Spartan 3E will probably run Linux extremely slowly. with Limited IO. Probbaly no hard storage, and likely no USB.
    A Rasberry Pi is $30, and very capable of running linux, with lots of IO options.
  18. #18
    Feb 2014
    638
    4,730
    16
    No, FPGA's can be faster than a processor but usually at a specific or specialized task.
    There is a reason FPGA's are comparatively less common than processors and the reason is that they are generally NOT faster or more cost effective than a well specified processor for most tasks.
    FPGA's have a role in low volume products, highly parallel and specialized tasks.
    •   AltAdvertisment
  19. #19
    Full Member level 1
    Dec 2017
    Bydgoszcz - Poland
    102
    820
    you can not because Linux for FPGA is almost kernel + basic packages. There aren't repositories with packages from Kali Linux for FPGA and particular SoC (like Zynq of soft-processor).
    You have to compile all packages from sources what for time constraints and needed knowledge is impossible to do.
    BTW: Linux for FPGA's is very basic OS system for embedded solutions (and writing custom peripherals in HDL languages like VHDL or Verilog).
  20. #20
    Full Member level 3
    Jun 2014
    158
    1,564
    9
    So if I understood correct, it is possible to build a hardware on a FPGA by seeing what specifications does a LINUX OS has...??
