Results 1 to 9 of 9
    Points: 30, Level: 1
    Sep 2018
    30
    4 bit register having parallel flip flops using VHDL
    Hello Everyone
    I am learning VHDL. i want to design a register with four parallel flip flops with common clock. can anyone help me in this regard?
    Sep 2018
    30
    Re: 4 bit register having parallel flip flops using VHDL
    Thanks KlausSt. but I want to make it using four instances of D flip flops.
    i have written this code. can you please verify it.
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    library IEEE;
    use IEEE.std_logic_1164.all;
    entity reg4 is
       port (d   : in std_logic;
          clear  : in std_logic;
          clk    : in std_logic;
          Qout     : out std_logic);
    end reg4;
    architecture behave of reg4 is
    signal Q0,Q1,Q2 : std_logic ;
    component DFF is
    port(D,Clock:in std_logic; Q:inout std_logic);
    end component DFF;
    begin
    FF0: DFF portmap(D=> 1,Clock =>clk, Q=>Q0);
    FF1: DFF portmap(D=> Q0,Clock =>clk, Q=>Q1);
    FF2: DFF portmap(D=> Q1,Clock =>clk, Q=>Q2);
    FF3: DFF portmap(D=> Q2,Clock =>clk, Q=>Qout);
    end behave;
    •   AltAdvertisment
    Points: 72,643, Level: 65
    Apr 2014
    14,783
    72,643
    65
    As this is a very basic problem...
    I recomend you to go through some basic VHDL tutorials.
    There are internat pages, PDFs as well as videos.
    although ´m not familair with VHDL...
    I came across an online tutorial and within a couple of minutes I modified the example to the following code.
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    ENTITY register4 IS PORT(
        d   : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
        clk : IN STD_LOGIC; -- clock.
        q   : OUT STD_LOGIC_VECTOR(3 DOWNTO 0) -- output
    END register4;
    ARCHITECTURE description OF register4 IS
    BEGIN
        process(clk)
        begin
            if rising_edge(clk) then
                q <= d;
            end if;
        end process;
    END description;
    It shouldn´t be far away for a 4 bit register. Maybe someone can check this.
    Hi, (sorry for the wrong order of posts)
    As said I´m not familiar with VHDL, but your solution rather looks like a 4 bit serial shift register....with "1" as input instead of "d". It looks weird to me.
    •   AltAdvertisment
    Sep 2018
    30
    Thanks Klaus. but i want to make it using instances of four flip flops
    i have written this code. someone please verify it
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    entity reg4 is
    port(D,clk : in bit;
           Q: out bit);
    end reg4;
    component DFF
    port(D,clk :inbit; Q:outbit);
    end component;
    signal Q: in bit_vector(2 downto 0);
    begin
    DFF0: DFF portmap(D =>1, clock =clk, Q=>Q0);
    DFF1: DFF portmap(D =>Q0, clock =clk, Q=>Q1);
    DFF2: DFF portmap(D =>Q1, clock =clk, Q=>Q2);
    DFF3: DFF portmap(D =>Q2, clock =clk, Q=>Q);
    end behave;
    •   AltAdvertisment
    Points: 37,347, Level: 47
    Jun 2010
    6,792
    37,347
    47
    This is just a 4 bit shift register that shifts in '1'. It can never be reset. What are you trying to achieve.?
    It also has syntax errors.
    You should try to compile the code first, and fix the syntax errors.
    Sep 2018
    30
    i could not find code on internet. can you please provide me code for 4 bit parallel register using instances of four flip flops.?
  7. #7
    Points: 7,813, Level: 21
    Apr 2016
    1,646
    7,813
    21
    Quote Originally Posted by asad_khan5130 View Post
    go do your homework. what you need can be described in less than 10 lines of code.
    Really, I am not Sam.
  8. #8
    Sep 2018
    30
    any error in this code?
    entity reg4 is
    port(d0,d1,d2,d3, clr,clk : in bit;
           q0,q1,q2,q3 : out bit);
    end reg4;
    architecture structure of reg4 is
    component DFF
    end component;
    begin
    DFF0: DFF portmap(d0, clock, q0);
    DFF1: DFF portmap(d1, clock, q1);
    DFF2: DFF portmap(d2, clock, q2);
    DFF3: DFF portmap(d3, clock, q3);
    end behave;
    •   AltAdvertisment
  9. #9
    Jun 2010
    6,792
    37,347
    47
    Why not run it through a compiler and find out?
