Results 1 to 17 of 17
    Junior Member level 1
    Points: 78, Level: 1
    Aug 2018
    16
    78
    lookup table implementation in verilog
    how to store the following values in a lookup table (2 dimensional memory) which is connected at the output of 8 bit latch in verilog ??
    values to be stored are 0.011,0.087,-0.045,-0.415
    Points: 68,591, Level: 63
    Apr 2014
    14,008
    68,591
    63
    Re: lookup table implementation in verilog
    I just see 4 floating point values....
    How are they related to "8 bit"?
    I canīt see "2 dimensional" nor can a floating point value fit into "8 bit"
    --> Please elaborate your question.
    •   AltAdvertisment
    Aug 2018
    16
    78
    This is the figure i was talking about .
    i'm doing a project on design of a low power logarithmic arithmetic unit . As you know logarithmic addition is complicated which is given by logb(x+y)=logbx+logb(1+b^-(logbx-logby)) . so a lookup table is required for computing the 2nd part of the logarithmic addition function . if you carefully observe the figure which i posted in previous reply -
    X and Y are two 8bit numbers .
    sx=X[7]
    sy=Y[7]
    x=logX
    y=logY
    d is an 8 bit register
    d=x-y
    d0 is the LSB bit which is used for enabling the latches . so in the figure shown , the 4 latches receive d[7:1]
    Till this point i coded everything and i got the simulations perfectly . now 4 lookup tables should be connected at the output of 7 bit latches out of which
    the first two represent addition function and the rest two represent subtraction function . I theoritically calculated the function values and obtained 0.0111,0.087,-0.045,-0.415 respectively . so , my doubt is how do i store these floating point numbers in a memory (lookup table) in verilog ? could you please help me out
    Apr 2014
    14,008
    68,591
    63
    still unclear where are the floating point numbers.
    From the text I assume it is d, but d is an 8 bit value, which is not suitable for floating point.
    Or are you talking about fixed point? Where and what format?
    Btw: Itīs not very usual to use floating point values in an FPGA - but not impossible if the application really needs it.
    Aug 2018
    16
    78
    here i need to partition the lookup table based on sd0 which acts as enable . latches are used to freeze the address of lookup tables . At a time only 1 lookup table will be active . i have to connect 4 such LUT's to the latches . how to store these values in a memory in verilog 0.0111,0.087,-0.045,-0.415 respectively . can you give me the direct verilog syntax for this ?
    Full Member level 3
    Points: 1,118, Level: 7
    Apr 2017
    161
    1,118
    7
    You can't store those value in 8-bit vector.
  7. #7
    Aug 2018
    16
    78
    Then how can I store it ? Will you please tell me any other way
    •   AltAdvertisment
  8. #8
    Points: 22,398, Level: 36
    barry's Avatar
    Mar 2005
    California, USA
    4,284
    22,398
    36
    There are many different ways of representing floating point numbers. Using 8 bits is not one of them. Do a search on IEEE 754 for one format.
    •   AltAdvertisment
  9. #9
    Aug 2018
    16
    78
    Floating point representation in Verilog
    how to represent these numbers in verilog?
  10. #10
    Apr 2014
    14,008
    68,591
    63
    What new information are you wating for?
    8 bit is impossible.
    Thus:
    * either choose a fixed point format (with your desired range and resolution. No one can do this for you)
    * or choose a standard floating point format. (very common is the 32 bit binary format)
    There are online calculators for decimal (float) to binary (float) and vice versa calculations.
  11. #11
    Aug 2018
    16
    78
    hello i used combinational logic for implementing LUT by using case statements . whatever values i gave are not coming exactly in the simulation. only integer part is coming and fractional part is not comimng . for ex: 5.734 . my simulation is showing only 5 . how do i get the exact values ?
  12. #12
    Full Member level 3
    Apr 2017
    161
    1,118
    7
    Quote Originally Posted by krishvamsi View Post
    It seems that your design does not work properly - it might be wrongly designed.
  13. #13
    Aug 2018
    16
    78
    you didnt get my question. there is nothing wrong in the design . by using case statements i only assigned outputs for corresponding inputs as 0.011,0.087,-0.045,-0.415 . but in the simulation all 0's are coming . do u know how to assign the above numbers in verilog ? please help me out . i got stuck here from so many days
  14. #14
    Apr 2014
    14,008
    68,591
    63
    No wonder.
    * Ignoring our posts about dataformat
    * not showing your code / design
    * not showing your simulation / simulation results
  15. #15
    barry's Avatar
    Mar 2005
    California, USA
    4,284
    22,398
    36
    There is nothing wrong with the design other than it doesn't work.
    Good luck.
  16. #16
    Full Member level 3
    Apr 2017
    161
    1,118
    7
    If you are sure that your design is 100% correct try to contact with your's tool manufacturer.
    •   AltAdvertisment
  17. #17
    Points: 29,773, Level: 42
    ads-ee's Avatar
    Sep 2013
    USA
    6,857
    29,773
    42
    Quote Originally Posted by filip.amator View Post
    Design is obviously not 100% correct.
    e.g.
    Code Verilog - [expand]
    wire [7:0] sig1;
    assign sig1 = 0.011; // always assigns 0 to sig1 as only the integer part is assigned
    wire [7:0] sig2;
    assign sig2 = 18.0235; // results in the value 8'b 0001_0010 (18 - integer part) being assigned to sig2
    As was already pointed out in previous replies: you can scale the values, use a fixed point format, or use some floating point format.
    Given your track record you'll probably just ask how to assign your values again.
