Results 1 to 20 of 20
    Points: 2,404, Level: 11
    May 2007
    39
    2,404
    11
    VHDL: writing codes that have smallest footprint on FPGAs
    I wanted to create this thread to gather information about the syntax of VHDL that yields the smallest circuitry in synthesis.
    Now, as we know that the best way to write codes that yields the smallest circuitry in Synthesis is through library functions. The worst part of these codes comes when you want to port the same code on different FPGA(i.e from Xilinx to Altera).
    That mean such codes should be generic so that these can easily be ported towards other platforms.
    If you know some of such techniques in VHDL, that produces least circuitry after synthesis then it will be of great value(across different platforms) i.e As I know that if else statement produces more circuitry than ternary operator in Verilog. Similarly, default value in Case structure invokes memory elements, and thus produces more circuitry. But these examples are from Verilog. Want to know such techniques in VHDL.
    Please share your knowledge, any link or document on this topic.
    Tahir
    Points: 37,347, Level: 47
    Jun 2010
    6,792
    37,347
    47
    Re: VHDL: writing codes that have smallest footprint on FPGAs
    There is no one answer to this, as each application will be different. But I would argue most of your assertions are wrong.
    Using library primitives is definitely not the best approach for the smallest option. Unless you are good with placing gates you may restrict optimisations available in the synthesis optimisations. Plus unless you have an optimal solution drawn out, it isn't necessarily optimal. And it will be terrible for any other engineers to pick up.
    Also, a deafault in a case statement won't always produce a memory element, it depends on the code. Same with an others choice in vhdl, it is situational.
    If else isn't necessarily worse than if else, it can produce the same circuit.
    For any language, the best code is one that is well documented and can easily be picked up by another engineer. Id I would always choose this over a highly optimized but difficult to understand design (these designs are usually the least flexible and often get scrapped when changes are needed)
    May 2007
    39
    2,404
    11
    Quote Originally Posted by TrickyDicky View Post
    So what to do when you badly need to save the space on FPGA?
    Jun 2010
    6,792
    37,347
    47
    Modify the code to reduce resource usage. How this is done will be dependent on the design. Often it may require removing whole blocks.
    •   AltAdvertisment
    Points: 7,803, Level: 21
    Apr 2016
    1,642
    7,803
    21
    This is absolutely not true.
    Really, I am not Sam.
    Full Member level 1
    Points: 1,529, Level: 8
    Nov 2013
    117
    1,529
    8
    I would argue that generally the ternary operator produce less circuitry than if-else. This happens because the ternary operator always require the "else" (or :), while one can skip the else when using if-else statements.
    An alone "if" instruction may be implemented as a enable or other weird optimizations, while "if-else" or "?:" are usually implemented as flip-flops or mux. Not that using a "if" as enable is always a bad thing, but it may generate a bigger circuit depending of utilization.
    Other point to argue is that ternary operator usually is easier to optimize (visually speaking) than if-else statements.
    •   AltAdvertisment
  7. #7
    Apr 2016
    1,642
    7,803
    21
    Makes no sense. You must compare apples to apples. the example below is logically equivalent.
    a = (cond) ? 0 : 1;
    if (cond)
     a = 0;
    else
    a = 1;
  8. #8
    Full Member level 1
    Nov 2013
    117
    1,529
    8
    Yes, but when you have a chain of "if-else", they can be different.
    For example, the codes below produces the same result, but produces a different circuit:
    if (cond == 1'b1)
    begin
      if (b == 3'b000)
        a <= c;
      else if (b == 3'b001 && s == 1'b0)
        a <= c+1;
      else if (b == 3'b001 && s == 1'b1)
        a <= c-1;
      else if (b == 3'b010)
        a <= 0;
      else if (b == 3'b011 && s == 1'b0)
        a <= c+d;
      else if (b == 3'b011 && s == 1'b1)
        a <= c-d;
      else if (b == 3'b100)
        a <= c*d;
    end
    Use ternary op, one possibility is to describe the same is:
    a <= cond == 1'b1 ? b == 3'b000 ? c             :
                        b == 3'b001 ? s ? c-1 : c+1 :
                        b == 3'b010 ? 0             :
                        b == 3'b011 ? s ? c-d : c+d :
                        b == 3'b100 ? c*d           : a : a;
    In this case I found that if-else used less logic, but ternary logic produced was way faster.
    •   AltAdvertisment
  9. #9
    Jun 2010
    6,792
    37,347
    47
    The problem with if/else is that it implies priority. If you used a case statement you'd probably similar or the same result.
    But if I was another engineer taking your code 3 months after you left, I'd delete that ternary description for its terrible lack of clarity. Ternaries inside ternaries won't gain you any respect.
  10. #10
    Full Member level 1
    Points: 745, Level: 5
    Created Blog entry
    Apr 2018
    Gdańsk, Poland
    101
    745
    Blog Entries
    Quote Originally Posted by tahirsengine View Post
    (... not true sentences ...)
    (... more not true sentences ...)
    In general every design is different and must be analysed separately in case of generation the smallest circuitry.
    I would suggest to focus on functions that the design must do and write your own RTL description tailored for your needs.
    Do you need all the functionality that some large "of the shelf" IP Core provide or you need only some part of it? If we talk about the smallest circuitry, then maybe the only way would be to write your own RTL description of that smaller part.
    Another factor is to follow vendor recommendations. Find and read appropriate user guides.
    Of course the synthesis tool is another factor. You could compare results of the ISE/Vivado, Synplify from Synopsys and Quartus from Altera and pick the smallest circuit for the implementation step.
    To encourage me to help more, click on "Helpful Post" if you feel that I've helped you.
  11. #11
    May 2007
    39
    2,404
    11
    Quote Originally Posted by niciki View Post
    I am using Vivado to write and test my designs. So, how to compare my design results with Quartus or Synplify, as the target FPGA is also Xilinx FPGA(Zynq 7 series)?
    Guys,
    I appreciate your responses. Please be focused on VHDL.
    Thanks and cheers
    Tahir
  12. #12
    Points: 8,117, Level: 21
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,207
    8,117
    21
    Blog Entries
    You need to get the necessary tools for comparison.
    When the various tools have generated the synthesis report, look there in and compare the amount of LUT* (For Xilinx 7 series FPGA, * = 1..6) used in each case as a *basic* comparison.
    FPGA enthusiast!
  13. #13
    Apr 2016
    1,642
    7,803
    21
    Quote Originally Posted by pbernardi View Post
    if (cond == 1'b1)
    begin
      if (b == 3'b000)
        a <= c;
        a <= c+1;
        a <= c-1;
        a <= 0;
        a <= c+d;
        a <= c-d;
        a <= c*d;
    end
                        b == 3'b010 ? 0             :
    As noted above, these are not the same because of priority. My point still stands, you don't get better circuits from ternary operator. You could achieve the same with parallel ifs or a case statement. Don't blame the language when you misuse it.
  14. #14
    Points: 253,869, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,227
    253,869
    100
    At first sight, both codes implement the same priority. Also, priority only matters for not fully decoded or non-unique input conditions. In the present case, there are only some undecoded combinations, they either generate a latch (combinational) or keeping the previous registered state, identical in both cases as far as I see.
    Apart from this slightly sophistic consideration, I completely agree with all statements for using the clearest, most readable coding style.
  15. #15
    Full Member level 1
    Nov 2013
    117
    1,529
    8
    Why using a language artifice is a misuse?
    Because ternary operator is unusual, it means automatically it is wrong? Sorry to disagree with this. While I fully understand that people don't like to read it (mainly because they are not used to), but the use of ternaries cannot be defined as wrong or misuse by any means.
    Yes, a case could be used in the case above to produce the same circuit, but my focus was to illustrate a difference between "if-else" and ternary. There are cases where "case" cannot be used - for example, when you have different selector signals on MUX.
    Ternary is a very powerful operator, that usually provides a faster circuit, and people usually ignores it simply because they do not like to read it.
  16. #16
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,227
    253,869
    100
    "Faster" sounds unsubstantiated. Modern synthesis tools generate equal gate level circuits for functionally equivalent HDL code (e.g. ternary versus if else) in most cases. Nobody said that ternary operator is wrong, but tends to make code less readable.
    I feel that the discussed coding style question is only a minor point for effective FPGA usage. Design structure, algorithms, clocking and pipelining are much more important.
  17. #17
    Jun 2010
    6,792
    37,347
    47
    There is nothing wrong with the ternary operator. Using it as you did may even meet the op's goals of reducing logic. But our point is that while this may be the case (although in all languages, there is usually at least 2 ways to do the same thing) even if you you do improve logic use, if it is hard for others to understand, your effort may be for nothing in the larger scheme of things if no one bothers to use it. In industry, crap code is crap code, no matter how clever it is. Just because you're clever, no one likes a smart arse, and if someone doesn't understand it, they won't use it, and nothing is learned. No matter how clever you are or think you are.
    For stuff to stick, and others to learn, it has to be clever code that is also understandable by someone with less skill than yourself.
  18. #18
    Apr 2016
    1,642
    7,803
    21
    I will try again.
    There is nothing faster about the ternary operator. Claiming so is naive, and the example you have shown is not a good one.
    •   AltAdvertisment
  19. #19
    Advanced Member level 2
    Points: 4,707, Level: 16
    Feb 2014
    634
    4,707
    16
    I'd suggest just using this as the definition of clever.
    Echoing some comments above...syntax is basically irrelevant. HDL code describes actual hardware and it's the design of that hardware which dictates performance. Good code is clear code and clear code will be easily understood by both humans and synthesizers leading to good and predictable performance.
    Asking about syntax specifically is like asking how to draw a circuit differently to reduce BOM cost...it doesn't make much sense.
    There are some arguments to be had about synchronous resets vs asynchronous resets and impact on performance...but that's a design discussion not a syntax one.
  20. #20
    Advanced Member level 3
    Points: 5,911, Level: 18
    Feb 2015
    969
    5,911
    18
    The biggest place you can save logic is by understanding the problem and the requirements and then selecting good architecture choices. I don't think there is a "design patterns" equivalent for FPGAs. But such a thing would be great.
    For example, one design I saw had a network processor. Later, multiple channels were needed. So multiple modules were instantiated and some input/output arbitration was added outside these instances. This was even though other code would look up the channel state from small RAMs and then have only 1 FSM for all channels. The network processors also attempted to do all processing as if it needed to be done in 1 cycle, even though most processing was only needed once per packet. But don't worry, the modules had custom (undocumented) interfaces that saved some resources by not keeping the pipelined signals aligned if they didn't need to be.
