AllenD
Member level 5
Hi team,
May I please ask a few questions?
Part 1--deep nwell nmos guardring
I'm using TSMC 65nm pdk to layout an analog circuit. I noticed all the "nmos_rf" are in deep nwell process and "pmos_rf" are regular nwell process.
1. For pmos_rf, I can just connect the guard ring (created by PDK default) to my vdd mesh to create a good latch up prevention
2. For nmos_rf, there are only 2 level of guard rings created by pdk: a) The guardring in the pwell inside of the deep nwell, which connects the pwell to gnd. b) The guardring in the deep nwell, which connects the nwell to vdd.
Q1:My first question is that for latchup prevention, should I manually add another level of guardring to ground the p-sub surround the nwell for latch up consideration? Or is that since the pmos is well grounded, no feedback loop can be formed so there should not be a latchup?
Part 2--the power/ground mesh layout.
Previously, I was literally layout the rows and columns of horizontal/vertical M1/M2 thin traces for gnd/vdd and connect the trace to the guardring of my rf mos and appropriate place in the circuit. Recently, my professor have mentioned another approach:
1. Create a unit filler cell with a unit layout connect M1,3,5,7 to gnd and M2,4,6 to vdd
2. Add substrate contact form M1 to gnd.(He said there is no such thing as too much substrate contact)
3. Fill the opening in your layout with this small unit filler.
My questions is
Q2.In that case, is my local circuit is going to look like a valley surrounded from all 4 directions. I assume the way to connect two local cell is going to create another unit cell and leave one of the layer missing so my signal trace can use such layer to pass through?
Q3.My professor said In the case of add substrate contact in the unit cell, I should not add decoupling cap from vdd to ground in the unit cell. Can anyone explain why the decoupling cap and substrate contact are mutually exclusive?
Q4. To my understand, the purpose of such unit cell substrate contact is to prevent latchup. So if I add the third guardring as the Part1 to prevant latchup, is there any extra benefit for the substrate contact in the filler cells?
Thanks
My questions is
Thanks
