T
treez
We have an 40W offline LED driver which uses no electrolytic capacitors...only ceramic ones.
Also, it uses only sequence switched linear regulators, -no SMPS.
It is only surface mount components.
Optocouplers, resistors, caps, diodes, FETs, SFH5711 light sensor, MCP9701 temp sensor, MCP6001 opamp, BZX84C-XX zeners.
Do you think we will have problems at -40degC?
The PCB sits on a rubbery thermal pad which is on a heatsink
We are getting it in the oven at -40degc, but wonder if there are any long term effects.
The product is totally enclosed..no vent holes....a rubbery gasket makes the seal between the optic and the heatsink
