Results 1 to 3 of 3
    Points: 409, Level: 4
    Jul 2017
    38
    409
    Verilog Code: How to read count value when Trigger signal is high ?
    I want to read the out value with the condition when the Trigger signal (Trig_SG) is high. I have tried with below code but i didnt got proper output. Please suggest me.
    module Trigger_RTC
    input clk_50,
    //output Trig_SG,
    output reg Final_out
    reg out;
    reg Trig_SG=1'b0;
    always@(posedge clk_50)
    begin
    Trig_SG<=1'b1;
    if(Trig_SG==1'b1)
    begin
    out<=out+1;
    Final_out<=out;
    end
    else
       Final_out<=0;
    end
    endmodule
    Points: 264,284, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,181
    264,284
    100
    Re: Verilog Code: How to read count value when Trigger signal is high ?
    What do you expect as "proper output"? According to your code, Trig_SG will be activated at the first clock edge after power on reset and stay permanently on. You should see this in a simulation.
    Full Member level 1
    Points: 912, Level: 6
    Created Blog entry
    Apr 2018
    Gdańsk, Poland
    101
    912
    Blog Entries
    Where is the source of the Trig_SG and "out value" signals? Are they from external module/pin or driven internally inside Trigger_RTC module?
    Please give us more context about the function of this block. What do you want to do and what is the vicinity?
    You want to read the "out value", but the "out value" is not an input for this module. Also Trig_SG is not an input - so it is confusing.
    To encourage me to help more, click on "Helpful Post" if you feel that I've helped you.
