vinctal
Hi
I have simulated 2 circuit in PSPICE, Figure 1(a) and Figure 2(a) is a virtual ground circuit a voltage reference of 5Vdc The two resistors form a voltage divider so that Vcc/2 appears at the non-inverting input of the op amp. Since it is set up as a follower, Vcc/2 also appears at the output.
Can someone explain to in Figure 2(b) why the output voltage is equal to Figure 2(a) ?
Thank you
Thank you
