preethi19
Full Member level 5
can any1 tell plz how to solve a setup hold confliting path in the same corner. Normally for a setup path, one of the possibility is to skew the clock. Skewing clock is usually done at the capture flop CK pin. But I was suggested from my senior that another way is also that we can even borrow from the previous path (if there is enough margin). Its like cutting a point in the clk tree.. This would give enough margin for setup so then hold can be fixed. I didn't understand this part.. Can plz explain me.
