electronicsman
Full Member level 5
I want to clarify suppose if i want to measure the resistance between two points in micro controller hardware board using multimeter, can i do it when it is powered on or i can do it only after powering off.
Why? What's the use of it?measuring resistance between Can-high and Can-low lines.
That is for confirming 120 ohm resistance between the lines.Why? What's the use of it?
Klaus
