Results 1 to 8 of 8
    Member level 5
    Points: 534, Level: 4
    Jan 2018
    92
    534
    How to bias a pHEMT (CS) for LNA application?
    If you go to the bottom of the datasheet for passive biasing with an ATF-55143 transistor, they use a bias point of 2.7V and 10 mA with Vdd at 3V. This doesn't make sense to me to have Vq at 2.7V since an LNA is suppose to be in class A operation, right?meaning that Vq should equal 1/2Vdd, correct? The datasheet is shown in the link here: https://www.google.com/url?sa=t&sour...E0RJO36Pyqf77l
    •   AltAdvertisment
    Points: 27,281, Level: 40
    BigBoss's Avatar
    Nov 2001
    Turkey
    3,923
    27,281
    40
    Re: How to bias a pHEMT (CS) for LNA application?
    VDS (max) is 5V..
    What else you would expect ?? The resistance has been used for-perhaps-stability or Current Limiting purposes..
    Member level 5
    Jan 2018
    92
    534
    Do you mean R1? And how does that resistor relate to class A biasing?
    •   AltAdvertisment
    BigBoss's Avatar
    Nov 2001
    Turkey
    3,923
    27,281
    40
    Quote Originally Posted by skatefast08 View Post
    R1,R2,R3 are biasing resistors.R3 limits the Drain Current with R1 and R2.
    Didn't you read the Datasheet ??
    Member level 5
    Jan 2018
    92
    534
    Yea I understand that, but why do they pick Vdd=3V? Why not 5V, since then Vds=2.7V would be about half of 5V? Also they put bias point at Iq=10mA, which also isnt even half of the max current.
    Points: 10,776, Level: 24
    Apr 2014
    1,698
    10,776
    24
    Voltage: 5V is the absolute max rating. The device seems targeted at mobile devices, which typically have 3.7V LiIon batteries.
    Current: Why would you bias to absolute max current rating?
    •   AltAdvertisment
  7. #7
    Member level 5
    Jan 2018
    92
    534
    Quote Originally Posted by volker@muehlhaus View Post
    I said I would bias Id at 1/2 of max current and bias Vds at 1/2 of max voltage. This way my q point will be in the middle of the IV characteristic curve, which will achieve class A operation, right?
  8. #8
    BigBoss's Avatar
    Nov 2001
    Turkey
    3,923
    27,281
    40
    Iq:Quiescent Current
    So, Peak-to-Peak swing will be 20mA that is under the limit of the transistor.
    This OP has been selected because it's a Low Noise Amplifier so the Best Noise Figure has been obtained on that Operating Point.
    Read carefully the datasheet..You cannot select the Op as you wish, there are many constraint.
