bit_an
Junior Member level 3
Kindly help me with a suggestion. How can I calculate the load impedance given in the picture. I am designing a differential input and single ended output Op-Amp to drive this load. I need to know the load values, but I am not sure about if the capacitors are in series or parallel in the small signal model. I need the small signal model to design a miller compensation inside my Amplifier. So i need to calculate the equivalent load at the output.
