Results 1 to 2 of 2
    Junior Member level 3
    Points: 640, Level: 5
    Dec 2015
    26
    640
    How to simulate E near field in HFSS
    hello friends
    i have a question ,
    how to simulate E near field in ansys HFSS ?
    i want to simulate E field in 3cm from pcb edge and plot |Ez| per frequency , like this figure ,
    thanks a lot.Click image for larger version.
    •   AltAdvertisment
    Advanced Member level 3
    Points: 6,431, Level: 19
    Jun 2012
    Edmonton, Canada
    997
    6,431
    19
    Re: How to simulate E near field in HFSS
    Hi amir_rch,
    Insert a line into your HFSS simulation, then simulate. In the field calculator, select mag(ScalarZ(E)) and save it as a calculated value.
    When plotting, select "Create Fields Report". Under "Geometry" select your line, and then select your MagE value to plot from "Calculator Expressions".
    Good Luck!
