IR remote-control receiver design - getting it stable
prairiedog
Canada
The best (discrete) IR remote-control receiver I have ever used, a Hitachi design from an old JCTV-3100. Fantastic range over 50m and used in large halls, works with IR bouncing off many surfaces :thumbsup:
I duplicated the circuit on a PCB. Works but it is oscillating at around 58kHz, and does pick up AM radio. It has a fair bit of noise and is very sensitive- putting a grounded probe near Q2 can lessen the oscillations. Putting a finger inches anywhere near the front-end it picks up interference. A wire mesh covering the photo-diode stops the AM radio ingress. A metal shielded enclosure, like the original has helps but it is still baffling me with the 58kHz. The transformer is tuned to 38kHz.
Adding a 68pF cap across C-B on Q4 stabilizes (fixes) the circuit but also lowers sensitivity (at 38kHz). This is the best I could come up with.
Any ideas how to tame the bandwidth and stabilize the circuit? The PCB has a ground-pour on both sides and does not seem to be the problem, and power is clean, 9V battery gives same results.
I don't agree.
A copper pour in my eyes isn't much better than single wires. Every cut reduces the HF stability of the GND plane.
Thus I recommend to show us your PCB layout.
The original Hitachi design was split into two (single-sided) boards. "Photo Amp" with metal can shielding Q1-Q3 and then a connector & shielded cable to the second board with Q4-Q7. I measure about 120pF capacitance on that cable, it would be from C8 to GND.
I put it all on one new PCB:
Original Hitachi build:
Your pictures show many different designs.
I can't find out which one is your current design.
Sorry, here are pictures of just what I built.
I wonder why all your transistors are not in the same orientation than the silk screen shows.
