promach
View attachment inv.zip
I am facing the following error when using asco circuit optimizer for a simple CMOS inverter.
Could anyone help ?
inv.cfg
inv.sp
extract/ROUT
Could anyone help ?
[phung@archlinux inv]$ asco-test -ngspice inv.sp
ASCO-0.4.10 - Copyright (c) 1999-2016 Joao Ramos
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
INFO: ngspice initialization on 'archlinux'
INFO: Initialization has finished without errors
DEBUG: evaluate.c - Executing errfunc
INFO: evaluate.c - altermc=2
DEBUG: errfunc.c - Step1
DEBUG: errfunc.c - Step2
DEBUG: errfunc.c - Step3
DEBUG: errfunc.c - Step4
errfunc.c - WriteToMem -- Data not read for measurement in *.cfg: ROUT
INFO: auxfunc_measurefromlis - WriteStats -- Data was not read for ZROUT0.
DEBUG: errfunc.c - Step7
INFO: errfunc.c - Step7 -- altermc=2
DEBUG: errfunc.c - Step8
DEBUG: evaluate.c - Leaving errfunc
INFO: evaluate.c - altermc=0
inv.cfg
#Optimization Flow#
Alter:yes $do we want to do corner analysis?
MonteCarlo:no $do we want to do MonteCarlo analysis?
AlterMC cost:3.00 $point at which we want to start ALTER and/or MONTECARLO
ExecuteRF:no $execute or not the RF module to add RF parasitics?
SomethingElse: $
#DE#
choice of method:3
maximum no. of iterations:50
Output refresh cycle:2
No. of parents NP:10
Constant F:0.5
Crossover factor CR:1
Seed for pseudo random number generator:3
Minimum Cost Variance:1e-6
Cost objectives:10
Cost constraints:10000
# ALTER #
.control
*alter vdd=[2.0 2.1 2.2]
run
.endc
*.protect
*.inc [../models/cmos035_slow.mod ../models/cmos035_typ.mod ../models/cmos035_fast.mod]
*.unprotect
*.temp [-40 +25 +85]
.param
+ V_SUPPLY=[2.0 2.1 2.2]
*.protect $ As much as 6 variables can be swept at the same time.
*.lib hl49ciat57k5r200.mod [mos_wcs mos_nom mos_bcs] $ Format is [a] or [a b] or ... [a b c d e f] =>1 space
*.unprotect $ and not :[ a], [a ], [ a ] => space is not really necessary
*.temp [-40 +25 +85] $ and not :[a b] => only 1 ' ' between 'a' and 'b'
*.param $ Add '*' to skip a line
*+ vddd=[2.25 2.50 3.30] $
*+ kc=[0.95 1.05]:LIN:10 $ LIN not yet implemented
*+ kr=[0.87 1.13]:LOG:10 $ LOG not yet implemented
*+ Ierror=[0.7 1.3]
*+ k00=[0 1]
*+ k01=[0 1]
*+ k02=[0 1]
*+ k03=[0 1]
*+ k04=[0 1]
*+ k05=[0 1]
*+ k06=[0 1]
*+ k07=[0 1]
*+ k08=[0 1]
*+ k09=[0 1]
#Monte Carlo#
NMOS_AVT:12.4mV $ This values will be divided by sqrt(2) by the program
NMOS_ABETA:7.3% $ 'm' parameter is taken into account
PMOS_AVT:10.9mV $
PMOS_ABETA:3.7% $
SMALL_LENGTH:0.0u $ Small transistors if l<= SMALL_LENGTH
SMALL_NMOS_AVT:20mV $ Small transistors parameters
SMALL_NMOS_ABETA:10% $
SMALL_PMOS_AVT:10mV $
SMALL_PMOS_ABETA:5% $
R_DELTA:0.333% $ Resistors matching at 1 sigma between two resistors
L_DELTA:0.333% $ Inductors matching at 1 sigma between two inductors
C_DELTA:0.333% $ Capacitors matching at 1 sigma between two capacitors
# Parameters #
Supply voltage:#V_SUPPLY#:2.0:0:0:LIN_DOUBLE:---
Temperature:#TEMP#:25:0:0:LIN_DOUBLE:---
Minimal gate length:#LMIN#:0.35u:0:0:LIN_DOUBLE:---
Input frequency:#INP_FREQ#:850E6:0:0:LIN_DOUBLE:---
PMOS width:#WP#:10000u:1m:10m:LIN_DOUBLE:OPT
*Output voltage:#V_OUT#:1:1:5:LIN_DOUBLE:---
# Measurements #
*P_SUPPLY:---:MIN:0
ROUT:OUT:GE:60E3
# Post Processing #
#this is the last line
inv.sp
*CMOS inverter http://electronics.stackexchange.com/questions/383552/measurement-of-output-impedance-of-a-cmos-inverter
.PARAM V_SUPPLY = '#V_SUPPLY'
*.PARAM INP_FREQ = '#INP_FREQ#'
*.PARAM INP_PERIOD = '1/INP_FREQ'
*.PARAM NO_PERIODS = '4'
*.PARAM TMEAS_START = '(NO_PERIODS-1)*INP_PERIOD'
*.PARAM TMEAS_STOP = '(NO_PERIODS)*INP_PERIOD'
.PARAM AC_POINTS = 10
.PARAM AC_START = 1000
.PARAM AC_STOP = 1E6
*** *** SUPPLY VOLTAGES *** ***
VDD VDD 0 {V_SUPPLY}
VSS VSS 0 0
*** *** INPUT SIGNAL *** ***
** VSIG IN VSS 0
** VSIG IN VSS AC 1 DC 0
** VSIG IN VSS AC 1 DC 'V_SUPPLY/2'
*** *** CIRCUIT UNDER TEST *** ***
MP OUT IN VDD VDD P1 W='#WP#' L=#LMIN#
MN OUT IN VSS VSS N1 W='#WP#/2' L=#LMIN#
** CL OUT VSS 3p
** RIN IN VSS 1G
CIN IN VSS 1
Rf OUT IN 1E15
** Lf OUT IN 1E-15
** The input can be either biased with a DC source, or a DC feedback circuit. Using a DC feedback circuit (RC, inductor, whatsoever) makes only sense if there's no DC voltage source, see https://www.edaboard.com/showthread.php?377214-Noise-in-CMOS-Inverter&p=1617292&viewfull=1#post1617292
*** *** ROUT TEST SIGNAL WITH FIXED 1A CURRENT *** ***
** this is a way to measure or plot the current source IOUT in spice using 0V voltage source
VOUT OUT VOUT 0
*VOUT VOUT 0 '#V_OUT#'
*** *** IOUT flows into the output of the circuit under test, so negative terminal node of this current source is OUT instead of VSS
IOUT VSS VOUT AC 1
*IOUT OUT VOUT AC 1
*** *** ANALYSIS *** ***
.AC dec 'AC_POINTS' 'AC_START' 'AC_STOP'
*.TRAN 'INP_PERIOD/1000' 'NO_PERIODS*INP_PERIOD'
*.PROBE TRAN V(IN)
*.PROBE TRAN V(OUT)
.OPTION POST PROBE ACCURATE
.include modelcard.nmos
.include modelcard.pmos
*.control
*AC dec 'AC_POINTS' 'AC_START' 'AC_STOP'
*AC dec 10 1000 1E6
*let ROUT=OUT/abs(i(VOUT))
*plot ROUT
*print ROUT > ROUT.log
*.endc
.END
extract/ROUT
# Info #
Symbol:ZROUT
Unit:Ω
Analysis type:AC
Definition:Output Impedance
Note:
# Commands #
.measure AC #SYMBOL# rms par('v(OUT)/abs(i(VOUT))')
*.MEASURE AC #SYMBOL# rms par('abs(i(vdd)*3)')
