Results 1 to 7 of 7
    Points: 363, Level: 4
    Sep 2017
    47
    363
    cant make sense of current, voltage, resistance relationship, graph
    I can't make sense of this graph
    I understand the relationship between V, I and R in written terms as in proportionality and the inverse. But I can't see how the graph relates. Can someone explain it please.
    •   AltAdvertisment
    Points: 7,312, Level: 20
    Jun 2015
    1,291
    7,312
    20
    Re: cant make sense of current, voltage, resistance relationship, graph
    You're not the only one. I feel like I'm walking into a trick question...
    It looks like the relationship has been drawn upside down. I've yet to see a circuit where less resistance equals less current...
    Sep 2017
    47
    363
    well thanks. It's not a trick. I can't make sense of it, and I guess it is wrong. But, what do i know? That is why I am asking. Is the graph upside down, or is it not possible to represent what its trying to represent with a single line?
    what about these graphs. I think the first one makes sense, but not the second. correct?Click image for larger version.
    •   AltAdvertisment
    Junior Member level 1
    Points: 371, Level: 4
    Feb 2017
    Philippines
    15
    371
    Hi. This looks pretty normal to me. If you take the voltage constant, say a constant voltage source with a resistor attached to ground then the current going through the resistor decreases as the resistance increases. Maybe we're used to seeing the current in the y axis but if you look closely, it does follow the V=IR relationship. if current increases (going left) resistance decreases (going down). But to control the current we need to adjust resistance that is why it is better to put current in the y-axis. the same applies to the other graphs.
    Points: 61,824, Level: 60
    Apr 2014
    12,611
    61,824
    60
    Post#1
    I agree the graph doesn't make much sense.
    There is Ohm's Law. R = V / I
    And it says "constant voltage"
    Let's calculate some values:
    Let's assume V = 12V
    Then: if
    I = 1A --> R = 12 Ohms
    I = 2A --> R = 6 Ohms
    I = 4A --> R = 3 Ohms
    I = 6A --> R = 2 Ohms
    I = 12A --> R = 1 Ohms
    You see: the higher the current, the lower the resistance.
    This is what the graph shows.
    Mind: the graph has no X values and no Y values. In most cases the axis are linear --> but there is no need for this.
    Thus one may expect that the graph shows a hyperbola --> but there is no need for this. With non linear axis the graph may look like a straight line.
    Post#3:
    Both graphs show the correct relationship:
    Constant R: the higher the current, the higher the voltage
    Constant current: The higher R, the giher V.
    Both are directly proportional. In both casess: with both linear axis you will get a straight line graph.
    I recommend to do some example calculations and graphs with Excel to get a feel.
    •   AltAdvertisment
    Sep 2017
    47
    363
    I think i have it then. Are the comments correct on the graphs attached?
    Basically the centre one is upside down, and all in all its a weird way to represent ohms law.
  7. #7
    Apr 2014
    12,611
    61,824
    60
    You are correct with figure 1.21 and figure 1.23.
    But you are not correct with figure 1.22.
    See my example of post #5.
    Mathematical solution:
    V = constant, thus V1 = V2
    V1 = R1 x I1
    V2 = R2 x I2
    because V1 = V2 we can say:
    R1 x I1 = R2 x I2
    Now we increase R2. Lets say R2 = 2 x R1
    Then we get
    R1 x I1 = 2 x R1 x I2 ; we divide both sides by R1
    --> I1 = 2 x I2
    I2 = 1/2 x I1
    we see that I2 is decreased.
    This is named "indirect proportionality"
    The higher R the lower I
    Added:
    Chart with non linear "R" axis.
