AshleeMakaya
Newbie
may you please help me rectify this problem. i am trying to start a pump and after a certain amount (1liter-4liters) of water, switch off the pump.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 #include "float2ascii.h" int sgr, wtr, vin, flr, mw, kp, set, conf; char txt1[7], txt2[7], txt3[7], txt4[7], txt5[7]; // Keypad module connections char keypadPort at PORTD; // End Keypad module connections sbit LCD_RS at RC1_bit; sbit LCD_EN at RC0_bit; sbit LCD_D4 at RC2_bit; sbit LCD_D5 at RC3_bit; sbit LCD_D6 at RC4_bit; sbit LCD_D7 at RC5_bit; sbit LCD_RS_Direction at TRISC1_bit; sbit LCD_EN_Direction at TRISC0_bit; sbit LCD_D4_Direction at TRISC2_bit; sbit LCD_D5_Direction at TRISC3_bit; sbit LCD_D6_Direction at TRISC4_bit; sbit LCD_D7_Direction at TRISC5_bit; // End LCD module connections char count = 0; unsigned long counter = 0; double litersPerSec = 0, litersFlowed, litersPerMinute = 0, litersPerHour = 0, pulsePerSec = 0; char str[30]; void interrupt() { if(INTF_bit) { counter += 1; INTF_bit = 0; } } void main() { Keypad_Init(); // Initialize Keypad Lcd_Init(); delay_ms(100); CMCON = 0x07; ADCON1 = 0x87; TRISA = 0xC0; TRISB = 0x01; PORTA = 0x00; PORTB = 0x00; // Initialize LCD Lcd_Cmd(_LCD_CLEAR); // Clear display Lcd_Cmd(_LCD_CURSOR_OFF); Lcd_Out(1, 1, "GLUE PRODUCTION"); // Write message text on LCD Lcd_Out(2, 1, "MACHINE PROJECT"); delay_ms(100); Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1, 1, "Ashlee P Makaya"); // Write message text on LCD Lcd_Out(2, 1, "H160305F"); delay_ms(100); error1: Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1, 1, "SELECT CONFIG"); // Write message text on LCD Lcd_Out(2, 1, "1, 2, 3 OR 4"); do { kp = 0; // Reset key code variable // Wait for key to be pressed and released do kp = Keypad_Key_Click(); // Store key code in kp variable while (!kp); // Prepare value for output, transform key to it's ASCII value switch (kp) { case 1: kp = 49; break; // 1 // Uncomment this block for keypad4x4 case 2: kp = 50; break; // 2 case 3: kp = 51; break; // 3 case 4: kp = 65; break; // A case 5: kp = 52; break; // 4 case 6: kp = 53; break; // 5 case 7: kp = 54; break; // 6 case 9: kp = 55; break; // 7 case 10: kp = 56; break; // 8 case 11: kp = 57; break; // 9 case 13: kp = 42; break; // * case 14: kp = 48; break; // 0 case 15: kp = 35; break; // # default: kp += 48; } Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1, 1, "MACHINE SET TO"); Lcd_Out(2, 1, "CONFIG : "); Lcd_Chr(2, 9, kp); // Print Configuration Setting delay_ms(100); if (kp == 49 ){ conf = 1; sgr = 300; flr = 190; vin = 10; wtr = 1; mw = 15; } else if (kp == 50 ) { conf = 2; // ASCII value sgr = 600; flr = 380; vin = 20; wtr = 2; mw = 30; } else if (kp == 51 ) { conf = 3; sgr = 900; flr = 570; vin = 30; wtr = 3; mw = 45; } else if (kp == 52 ) { conf = 4; sgr = 1200; flr = 760; vin = 40; wtr = 4; mw = 60; } else { Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1, 1, "INVALID SELECTION"); delay_ms(200); goto error1; } WordToStr(sgr, txt1); // Transform counter value to string WordToStr(flr, txt2); WordToStr(vin, txt3); WordToStr(wtr, txt4); WordToStr(mw, txt5); Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1, 1, "SUGAR: "); // Write message text on LCD Lcd_Out(2, 1, "FLOUR:"); Lcd_Out(1, 12, txt1); Lcd_Out(2, 12, txt2); delay_ms(200); Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1, 1, "VINIGAR: "); // Write message text on LCD Lcd_Out(2, 1, "WATER:"); Lcd_Out(1, 12, txt3); Lcd_Out(2, 12, txt4); delay_ms(200); Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1, 1, "LIESTERINE: "); Lcd_Out(1, 12, txt5); delay_ms(200); LCD_Cmd(_LCD_CURSOR_OFF); LCD_Cmd(_LCD_CLEAR); INTEDG_bit = 1; INTE_bit = 1; PEIE_bit = 1; GIE_bit = 1; INTF_bit = 0; do{ portb.f7 = 1; pulsePerSec = (double)counter; if (conf == 1) { if(pulsePerSec == 450 ) { portb.f7 = 0; } } else if (conf == 2) { if(pulsePerSec == 900 ) { portb.f7 = 0; } } else if (conf == 3) { if(pulsePerSec == 1350 ) { portb.f7 = 0; } } else if (conf == 2) { if(pulsePerSec == 1800 ) { portb.f7 = 0; } } litersPerSec = pulsePerSec / 7.5/ 60; litersFlowed = litersPerSec; Float2Ascii(litersFlowed, str, 2); strcat(str, " Liters"); LCD_Out(1,1,str); Float2Ascii(litersPerSec, str, 2); strcat(str, " Ltr/sec"); LCD_Out(2,1,str); }while(1); } while(1); }
