Verilog-a cyclically dependent error
heba_saleh
Newbie level 2
Dear all
I am new to verilog-a and symicaDe tool .. I want to write and read data from a file so I copied a simple veriloga code from the manual.
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
`include "disciplines.vams"
`include "constants.vams"
module fileexample;
integer mcd1 ;
integer mcd2 ;
integer mcd ;
analog begin
@(initial_step) begin
mcd1 = $fopen("file11.txt","a") ;
mcd2 = $fopen("file2.txt","a") ;
end
mcd = mcd1 | mcd2 ;
$fstrobe(mcd, "This is written to both files") ;
   $fclose(mcd1);
   $fclose(mcd2);
end
endmodule
However, i am getting as error ---->
cyclically dependent cells found: FileTest(I0) - FileTest(I0)
1 error(s), 0 warning(s)
I would be grateful if someone told me how to solve this problem
thank you in advance
@(final_step) begin
   $fclose(mcd1);
   $fclose(mcd2);
end //final_step
Show me netlist which call this verilog-A module.
simulator lang=local
parameters
I0 out x0 x1 nand2
subckt nand2 out in1 in2
V6 n3_1 gnd vsource type=dc dc=1.3
M7 out in1 n4_4 gnd n w=0.0001 l=1.3e-007
M9 out in2 n3_1 n3_1 p w=0.0001 l=1.3e-007
M10 out in1 n3_1 n3_1 p w=0.0001 l=1.3e-007
M8 n4_4 in2 gnd gnd n w=0.0001 l=1.3e-007
ends
TimeSweep tran start=0.000000e+000 stop=5.000000e-003 lteratio=3.500000e+000
save x1 x0 out
saveOptions options save=all currents=selected
DEFAULT_OPTIONS options tnom=2.700000e+001 temp=2.700000e+001  acout=0 fast_spice=0 reltol=1.000000e-003
this is the netlist
