[Moved]: How to code a Verilog to read .txt (hexa value )file and and then store in PC
vachanukb
Newbie level 2
[Moved]: Verilog code to read .txt (hexa value)file and and to store in PC
Hi all,
I need to code a verilog that could read the hexa value in a text file (.txt) and should save the value in a memory. The hexa value in a value are huge.
Can someone help me with this. Thanks in advance.
Re: [Moved]: Verilog code to read .txt (hexa value)file and and to store in PC
too vague. the verilog language has support for file reading, that solves your problem if you don't want to generate real hardware.
Thanks for your reply. Actually I am looking for verilog code that could import the .txt file (which has hexa values) and store the values in an array.
Thanks,
Vachan
Lookup $readmemh in the Language Reference Manual.
