Page 1 of 2 1 2 LastLast
Results 1 to 20 of 21
    Newbie level 6
    Points: 251, Level: 3
    Jul 2017
    13
    251
    How to detect start and end of CAN frame?
    Hello, I have a (probably easy) problem. I have two CAN transivers TR1 and TR2 and I need a logic whics detect a start and end of CAN frame - I mean, when e.g TX1 starts sending, the RX2 recives, TX2 sending frame to RX1, and RX1 is blocked as long as end of rame will be detect. And vice verca. Any ideas? Flip flops, or something?
    Points: 21,710, Level: 35
    barry's Avatar
    Mar 2005
    California, USA
    4,162
    21,710
    35
    Re: How to detect start and end of CAN frame?
    I believe CAN uses a specific byte to indicate the start and end of a frame. Detect two of those in a row, and that's the start.
    Newbie level 6
    Jul 2017
    13
    251
    But if frames are transive with delay, they will be not detected.
    barry's Avatar
    Mar 2005
    California, USA
    4,162
    21,710
    35
    Quote Originally Posted by frdm90 View Post
    I don't know that that means.
    No, I was wrong. CAN does not use specific start/stop byte values. I was confusing this with a different system I had worked on that was CAN-like.
    Points: 64,936, Level: 62
    Apr 2014
    13,193
    64,936
    62
    Did you look at wikipedia? https://en.wikipedia.org/wiki/CAN_bus
    there is an SOF = 1 x "0"
    and there is an EOF = 7 x "1"
    and ther is an inter frame space = 3 x "1"
    •   AltAdvertisment
    barry's Avatar
    Mar 2005
    California, USA
    4,162
    21,710
    35
    The problem is, how do you know whether a "0" is the SOF, or a bit in the middle of the message? You have to know that there is no active message. And if you know that, then you know the answer to the OP's originally question. I think.
    On further review, I'm not really sure what the OP wants. It SOUNDS like they want some hardware to detect the frames, without any software. That sounds nearly impossible. I think OP needs to explain this better.
  7. #7
    Apr 2014
    13,193
    64,936
    62
    To me it looks like:
    [frameSync]
    Wait for (at least) 11 x "1" at the end of the frame...
    Then wait for a "0" as start bit.
    Then sample the complete frame
    then check if CRC is correct
    --> If NO, then re-start with frameSync
    --> If YES, then the received Frame should be valid.
    •   AltAdvertisment
  8. #8
    Points: 29,308, Level: 41
    ads-ee's Avatar
    Sep 2013
    USA
    6,770
    29,308
    41
    EOF and IFS are used to detect bus idle, there is no other time when the bus is in a recessive state for that long when a frame is being transferred due to bit stuffing. Start of frame is signified by a dominant bit being sent. If two CAN transmitters start at about the same time they will both output a dominant sync bit and then start sending their message IDs, the message id with the smallest value wins arbitration, so the transmitter who loses has to go off bus. and wait until the next EOF IFS period and try again.
    And to further answer you question both receivers need to always monitor the bus (even when transmitting) to detect that the bits sent are not being dominated by another transmitter. So the logic needs to monitor what you transmit and compare to what you receive, so if your transmit outputs a recessive bit and you receive a dominant bit you go off bus during the arbitration phase.
    You really need to get the spec from Bosch if you want to design a CAN system, the wiki page isn't enough.
  9. #9
    Newbie level 6
    Jul 2017
    13
    251
    Well, iI neet to eliminate the echo between transceiver A and transceiver B. When tx1 broadcast to rx2, the rx1 is 'blocked'. RX receives this frame when tx1 stops brodcast.
    •   AltAdvertisment
  10. #10
    Apr 2014
    13,193
    64,936
    62
    Afaik: CAN bus is half duplex. It doesnīt have independent Tx and Rx paths.
    You need the "echo" for bus arbitration ... like ads-ee explained.
    Iīm not very experienced in CAN...
    If you want to work with CAN, then I recommend to read CAN bus specificaton first. Urgently.
  11. #11
    Newbie level 6
    Jul 2017
    13
    251
    Yes, but I mean tx and rx signals at CAN transceivers, e.g. TJA1042 - > there are rx and tx signals.
  12. #12
    Apr 2014
    13,193
    64,936
    62
    Again: Read specification!
    I only can repeat:
    For sure the transceiver has Rx and Tx at the microcontroller side. And you need both - at the same time - for collision detect / arbitration. You must not eliminate the "echo".
    The CAN bus is half duplex.
  13. #13
    Newbie level 6
    Jul 2017
    13
    251
    Well, I have read about CAN something more. So it is my idea, could You help me with that? I would like to connect TJA1055 and TJA1042. when TJA1055 is transmiting data with any speed (from 50kBs to 1 MBs). So if CAN is half-duplex, its mean then when TX1 is transmiting, RX1 is in iddle state, yes? When TX1 is transmiting to RX2, (red line), then TX2 is not transmiting to RX1 (blue line).
    So there is no logic needed to properly work?
  14. #14
    Apr 2014
    13,193
    64,936
    62
    No.
    1) Please show the source of information where it is said that TJA1055 (or any other CAN transceiver) will switch RXD to idle during transmitting?
    2) Show how you can do bus arbitration when RXD is idle during transmitting.
  15. #15
    ads-ee's Avatar
    Sep 2013
    USA
    6,770
    29,308
    41
    Your picture in post #9 doesn't correctly show the connection of a CAN bus.
    This is how a CAN bus is implemented...
    Notice the TXD and RXD are NOT connected together between transceiver devices. The bus is connected using the CANL and CANH signals.
    I don't think you've read and understood the datasheet for the PHY device if you plan on hooking up the TXD and RXD like you've shown. The TXD and RXD are the side that interfaces to some other device (usually a microcontroller) and is not part of the CAN bus it is the user interface to communicate with the PHY device. The CANL and CANH are the signals that make up the CAN bus.
    Anything sent on the TXD line will show up on the RXD line of a PHY with some delay and may have a recessive or dominant bit returned depending on the bit arbitration. e.g. if device 1 TXD1 sends a recessive bit but the RXD1 has a dominant bit then the arbitration of that bit is lost and the device 1 should go off bus.
    Because of the monitoring of the received data from the most distant device connected to CANL/CANH there are requirements for the delay/distance between PHY devices that must be met to meet the CAN spec. CAN can be (and is regularly) run at less than the 1 Mbps rate.
  16. #16
    Newbie level 6
    Jul 2017
    13
    251
    Thanks for explanation @ads-ee. Well, maybe I has not exactly say what I need. I need connect two transceivers, beacuse one is sending with low speed, and second is transmiting the same frame but with high speed. I was thinking about connection not directly, but a some logic between them (uC is probably the best option), to buffer this frame, and send it with high speed.
    Last edited by bassa; 10th July 2018 at 10:06. Reason: Remove external links and attached with the post
  17. #17
    ads-ee's Avatar
    Sep 2013
    USA
    6,770
    29,308
    41
    Mixing the two (CAN and CAN-FD) isn't possible on the same bus unless you add something to intercept the CAN-FD frame from reaching the CAN devices.
    You might want to look at this white paper on the subject.
    https://www.google.com/url?sa=t&rct=...Nary4x2kN3kKXo
    and/or this one.
    https://www.can-cia.org/fileadmin/re...013_monroe.pdf
  18. #18
    Newbie level 6
    Jul 2017
    13
    251
    Thanks, but i need only mixed CANH with CANL, it is not the same what mixed CAN and CAN-FD, is not?
  19. #19
    ads-ee's Avatar
    Sep 2013
    USA
    6,770
    29,308
    41
    There is no such thing as mixed CANH and CANL this post makes no sense whatsoever.
    Apparently you're using edaboard to learn about CAN and haven't made any effort to read the spec or read any of the online tutorials.
    •   AltAdvertisment
  20. #20
    Newbie level 6
    Jul 2017
    13
    251
    Hehe, yes i had to read about CAN :P. I nearly understood, but i dont know yet, what will be if we cross CANH wit CANL (CAN FD blanking transceiver). How it can works?
