Results 1 to 11 of 11
    Member level 3
    Points: 1,692, Level: 9
    Nov 2010
    57
    1,692
    9
    Altium 17.1 schematic to PDF print problem
    Has anyone faced a problem while printing schematic to pdf file a lot of text strings disappears, i.e. power port labels, pin and net label strings ect..
    Some of them not printed to pdf, while in schematic file they do exist.
    •   AltAdvertisment
    Points: 27,977, Level: 40
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,343
    27,977
    40
    Blog Entries
    Re: Altium 17.1 schematic to PDF print problem
    You can selec/deselect which primitives from schematic you want to print, from the Schematic Print Properties: https://www.altium.com/documentation...roperties))_AD or with the Smart PDF Wizard: https://www.altium.com/documentation...DF+Wizard))_AD
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Member level 3
    Nov 2010
    57
    1,692
    9
    Yes, I can select/deselect, but result is the same. Some text names are exported and some are missing. I get the same result if i do a print on paper directly from schematic.
    It was working properly some days ago, my guess is, if some Windows10 update might influenced this???
    Nov 2006
    Brazil
    8,343
    27,977
    40
    Blog Entries
    Just a guess: Try printing in Black and White insted of coloured; perhaps these primitives have the same color of the sheet background.
    •   AltAdvertisment
    Member level 3
    Nov 2010
    57
    1,692
    9
    Found the problem! Uninstalled last windows10 update (4284835) https://support.microsoft.com/en-us/...date-kb4284835
Name:	Screenshot 2018-06-29 14.10.28.png
    And PDF exporter works as it has to:
    3 members found this post helpful.
    •   AltAdvertisment
    Newbie level 1
    Points: 13, Level: 1
    Jul 2018
    13
    I am using Altium 17.1.6 on Windows 10-64bit. On PDF files some of the schematic symbols are missing pin names on the right hand side, and some do not have any pin names. Went back to Altium 16.0.8 and PDF files are correct.
  7. #7
    Newbie level 1
    Points: 1,546, Level: 8
    Feb 2010
    1,546
    8
    Comfirm that this worked for me.
  8. #8
    Newbie level 2
    Points: 29, Level: 1
    Aug 2018
    29
    Quote Originally Posted by tantudaisu View Post
    Has anyone faced a problem while printing schematic to pdf file a lot of text strings disappears, i.e. power port labels, pin and net label strings etc..
    YES!
    I have the same issue where global net names are missing on pdf outputs, but don't have on AD18 . However I am still using AD17.1.9 (build 592) as default on Windows 10 so it's a pain. I think it started with the last AD17 update that I installed a few weeks ago. I have checked print options & they are ok. I could not find a windows installation update called KB4284835 in my update list, but I have uninstalled the last security update for Windows 10 in July18 & it has fixed it. Not sure what will happen in the future when Windows Updates occur again.
    •   AltAdvertisment
  9. #9
    Newbie level 1
    Aug 2018
    13
    I was having this problem but the security updates weren't an option. I managed to find the solution here, and it worked for me: Go to: DXP -> Preferences -> Schematic -> General Uncheck the "Render Text with GDI+"
  10. #10
    Member level 3
    Nov 2010
    57
    1,692
    9
    Quote Originally Posted by bobbaddeley View Post
    Yes, this is the right solution. Thanks!
  11. #11
    Newbie level 2
    Aug 2018
    29
    bobbaddleley....well done!! Worked for me. The previous fix of uninstalling W10 security update was short term because IT reinstalled new updates. Thank you. Altium should be doing this!
