Can I connect a switch connected to the neutral line to 5v microcontroller?
Justeng
can i connect switch connected to nuetral line to 5v microcontroller ?
Hi,,,
can i connect switch connected to nuetral line of 220 v ac source to 5v microcontroller ?
if yes how can i do that ?
regards
Re: can i connect switch connected to nuetral line to 5v microcontroller ?
Not clear what you want to achive.
Show us a sketch of your idea.
Klaus
The question should not be How, but rather: Why ? It is not safe, unusual, and totally inadvisable (if not forbidden by any electrical regulation).
Klaus
the following figure describe what i mean ,
I assume the AC/DC device gives isolated output..
The the previously asked question is still vaid: Why?
It makes no sense. There is no return path and thus no current flow.
Why a pushbutton?
What´s your idea with the box [??]?
Klaus
Why a pushbutton?
Klaus
I have push button already connected to neutral line .. i want to get a signal from the button to do something using mcu.
[??]box : interface circuit between the switch and mcu,, iam asking about it :)
You want the pushbutton at the mains side to cause a logic signal at the microcontroller input?
Then I recommend to use some device with safety isolation: Optcoupler, transformer...
The shown circuit can´t work.
You always need a reference_signal (usually called GND) for every input signal.
But here the reference is missing.
Mind: you always need at least two lines for a signal.
* One is the signal of interest
* the other is eiter the reference_for_voltage or the return_path_for_currents.
Klaus
which is better?using optocoupler or transformer?
any schematic describe how can i use opto and transformer to do what i need ?
I know that :) ... thank you ^.^
Klaus
there are plenty optocoupler circuits and transformer circuits around.
Use the forum search ... this is how a forum should work.
For simply switch ON/OFF you may use a relay....maybe the best solution.
Klaus
Klaus
thank you :)
you mean use relay like this ?
Yes. A straight forward solution....if this is the function you need.
Klaus
