Is V = IR Correct as per the my example
pasidu
Member level 3
Dear All
Have a nice day!
Lest assume 1.5v AAA battery connect with copper wire ( short circuit)
Then
Copper wire resistance is ~ 0.1
Then as per the V + IR
I = V/R
I = 1.5/0.1
I = 15A
Is it correct ?
Please advice
Yes. For an ideal voltage source.
But real voltage sorces have internal resistance.
I don't know what's a realistic value for an AAA battery, but I assume it is higher than 0.1 Ohms.
No you should consider internal resistance of battery, it will resist the high current discharge when you shorting
