AC PIR Light Controller ELMOS E910.99?
berger.h
Member level 5
I have light with PIR and DARK sensors and have any fault, after and 230V on ligh bulb is shines all time.
Ligh is drive **broken link removed**
Connection is very simple as schematics in datasheet, but for AC and wit relay on switch 230V bulb.
As power source is RC transformer less 230/24V and work OK, respectively , if I for power use DC24V it behaves the same way.
C E910.99 is powered DC24V, on Regulator output 19 is 3,9V .on DARK input from Photo resistor is 0,7V , over it, 17 Reali switch relay 24V Relay ON.
I thing E910.99 is faut, because Voltages on Pin DARK of V < 1/4VDD are indicated as “not dark” (day),
Unfortunately, I was unable to find a seller, you can advise?
The manufacturer is interested in selling, therefore they give the informations:
then goto [Products] -> [Dstributors]
or:
