gcc is not recognized as an internal or external command
Daljeet12
Member level 4
Hello
I am trying to install gcc compiler I have downloaded and installed MinGW on windows 10. When I check program it give error
Command :gcc -o test test.c
program
Code C - [expand]
#include<stdio.h>
int main()
  printf("Hello world!");
  return 0;
Error
I guess the error cause of path variable. I edited path variable C:\MinGW\bin
I searched on the google but I couldn't resolve error. Anyone can help me
How did you add this path, are you sure you did it correctly ? Instead of edit it, try appending a new entry to the current path content by the following DOS line command:
set PATH=C:\MinGW\bin;%PATH%
I appropriate your help andre_teprom. This command works but now facing problem with jdk. when I type command javac in command line it give message on screen but now If I type javac it give error javac is not recognized as an internal or external command
I have installed latest version of jdk and eclips oxygen IDE for java but I guess I think there is problem with path variable.
What is correct path for jadk ?
Likewise, you should add Java path to the environment variables, something like this:
set path=C:\Program Files\Java\jdk<current_java_version>\bin;
Check on your program files directory for the correct java subdirectory folder name, and replace on the above command line.
I observed one thing, if i restart the system and after that I type Command :gcc -o test test.c it give the error. gcc is not recognized as an internal or external command.
I am following this video for javahttps://www.youtube.com/watch?v=Wp6uS7CmivE
