Results 1 to 5 of 5
    Points: 28,882, Level: 41
    Sep 2008
    cambridge
    6,052
    28,882
    41
    Flyback PFC passes mains harmonics
    The attached waveform is of a flyback pfc. The mains input current is slightly out of phase with the mains input voltage, however, it still passes all mains harmonics.
    Is this expected? Similar ones fail on the third harmonic.
    •   Alt13th June 2018, 20:06
      advertising
    Points: 6,565, Level: 19
    Dec 2015
    Madrid, Spain
    1,178
    6,565
    19
    Re: Flyback PFC passes mains harmonics
    Aren't you supposed to test it at 60W ? Why are you testing it at less than 35W?
    •   Alt13th June 2018, 20:41
      advertising
    Sep 2008
    cambridge
    6,052
    28,882
    41
    Thanks yes, you read my mind , it is actually a 60w flyback maximum...but we need to pass mains harmonics at all levels down to 25w, including the 35w version shown in the top post.
    •   Alt13th June 2018, 21:02
      advertising
    Points: 244,634, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,495
    244,634
    100
    What do you mean with "passes all mains harmonics"? There's no indication for harmonic behaviour in the posted waveform.
    Advanced Member level 3
    Points: 6,226, Level: 18
    Aug 2015
    978
    6,226
    18
    The results are surprisingly good, it would be a bonus if the flyback could keep switching thru the mains zero Xing - but sometimes you can't have everything - well done ...!
