Results 1 to 7 of 7
    Points: 70, Level: 1
    Apr 2018
    7
    70
    Inverter design problem
    Hi, I'm trying to design an Inverter based on arduino, here's the schematic and the code:
    The problem is that, measuring the voltage right after Q1 and Q2, I get a strange graph as you can see in the first image, here's the graph I expected:
    My question is why do I get that?
    Sorry if I asked a stupid question, but I'm still learning electronics.
    Thank you in advance for the answers.
    Points: 74,899, Level: 66
    Apr 2014
    15,188
    74,899
    66
    Re: Inverter design problem
    without knowing any voltage of your applicaiton ... all we can do is guess.
    Why making life harder than necessary?
    High side siwtiching usually is more complicated than low side switching.
    You will find a lot of similar applications all with low side switch....where the center tap of the tranformer is connected with the positive supply rail.
    Advanced Member level 2
    Points: 4,353, Level: 15
    Nov 2013
    655
    4,353
    15
    You swapped the PMOS source and drain. Protection diode is forward biased.
    "Try SCE to AUX." /John Aaron/
    Apr 2014
    15,188
    74,899
    66
    true.
    and even then there are some issues:
    * cross conducting: There is a short time every cycle where both MOSFETs are ON. Causing short circuit currents to flow.
    * this needs 100% of processing time. The microcontroller is not able to do anything else without causing probems with the tranformer.
    Points: 79,346, Level: 68
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,003
    79,346
    68
    The fundamental problem is the Arduino output is probably below the Vgs threshold of the MOSFETS anyway and certainly won't be enough to drive them to full conduction, especially with the load in the source pin. Remember that the gate has to be above the source voltage by >Vgs threshold before it even starts to conduct, consider how that would be possible if you already raised the primary voltage to push current into the transformer.
    You might be able to connect +V to the transformer center, with the drain pins to the ends and source to ground but I would still have serious reservations about drive levels unless you employ an additional driver stage. As Klaus points out, you also need a 'dead time' at the start of the next MOSFET turning on so there is no chance of both being conductive at the same time.
    Points: 9,710, Level: 23
    d123's Avatar
    Jun 2015
    1,717
    9,710
    23
    The circuit needs a level shifter which would be a gate driver IC suited to 3.3V logic level inputs, if not a level shifter (a BJT or a logic level MOSFET with a very low VGSth ON) followed by a gate driver IC. I would even consider placing a cheap optocoupler between that MOSFET and the nasty transformer and the pretty little delicate Arduino - I doubt the Arduino will enjoy that circuit, to be honest...
  7. #7
    Apr 2018
    7
    70
    Hi, thank you all for the answers!
    I changed my circuit and code like this:
    Now it works, I added a level shifter and made inverter's controller asynchronous to use the arduino for other purposes also.
    Do you have any suggestion left?
