Results 1 to 5 of 5
    Points: 293, Level: 3
    Feb 2017
    Nasipit, Talamban, Cebu City, Philippines
    293
    How to Simulate Designs with L=50um
    Hello Everyone,
    I'm trying to simulate the Design from the paper in [1] using HSPICE. The attached are the sizes and schematic of the design.
ID:	147191Click image for larger version.
    In HSPICE the max limit for L is 20um but the design uses 50um. How do I simulate this in HSPICE?
    [1] L. Magnelli, et. al., "A 2.6 nW, 0.45 V Temperature Compensated Subthreshold CMOS Voltage Reference," IEEE J. Solid-State Circuits, vol. 46, no. 2, pp.465-474, Feb. 2011.
    Best Regards,
    rmanalo
    •   Alt13th June 2018, 07:20
      advertising
    Points: 12,642, Level: 26
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    1,853
    12,642
    26
    Re: How to Simulate Designs with L=50um
    Connect three MOSFETs of L=50um/3=16.7um in series.
    •   Alt13th June 2018, 10:38
      advertising
    Feb 2017
    293
    Quote Originally Posted by pancho_hideboo View Post
    thank you for the reply, correct me if I'm wrong but wouldn't that increase the minimum supply voltage? (I'm thinking connecting three MOSFETs in series would mean having three times the drain-to-source voltage) Additionally all the transistors operate in subthreshold region. I'm not sure about the operation of composite transistors in this region.
    •   Alt13th June 2018, 10:49
      advertising
    Full Member level 5
    Points: 2,273, Level: 11
    Nov 2013
    296
    2,273
    11
    Quote Originally Posted by rmanalo View Post
    Draw the layout of the 3 series transistor, you will see it is equivalent with one longer device, total Vds will be the same.
    Not all of the series devices will operate in the same region, bottom devices will be in triode region, but the whole transistor will have very similar electrical properties as one long device.
    "Try SCE to AUX." /John Aaron/
    Points: 35,804, Level: 46
    Mar 2008
    USA
    5,758
    35,804
    46
    You might check where this limit is imposed, there may
    be checkboxes (GUI) or flag-variables (SPICE) that will
    defeat the error checking. You could also"take the
    models private" and edit whatever is the problem -
    difference between L=20 and L=50 is probably benign,
    and could be sanity-checked in simulation.
