Results 1 to 3 of 3
    Full Member level 6
    Points: 2,919, Level: 12
    Nov 2010
    336
    2,919
    12
    noise frequency of servo and vfd drives
    what will be the approximate noise frequency that servo and vfd motor drives create. i am choosing ferrate bead for that i must know the noise frequency level.
    •   AltAdvertisment
    Points: 68,549, Level: 63
    Apr 2014
    14,002
    68,549
    63
    Re: noise frequency of servo and vfd drives
    This means we need to guess what VFD you use. You over estimate our capabilities.
    I assume you know which VFD you use: Why not read the datasheet?
    •   AltAdvertisment
    Points: 250,686, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    43,645
    250,686
    100
    VFD switching frequency is in a 4 to 20 kHz range, depending on the power switch technology, voltage and output power.
    Ferrite beads are almost useless for the VFD fundamental frequency, the harmonic spectrum can't be directly derived from fundamental.
