Results 1 to 5 of 5
    Newbie level 3
    Points: 25, Level: 1
    Jun 2018
    25
    Timing Sign off from Primetime
    I am using Primetime for sign off of my ASIC , i am doing my eco fixes in PT ,but unable to write out a changes script for cadence innovus/encouter tool
    any who has done this please write how to write out a Encouter/Innovus Script for ECO Changes from Synopsys Primetime Tool ?
    •   AltAdvertisment
    Points: 7,288, Level: 20
    Apr 2016
    1,544
    7,288
    20
    Re: Timing Sign off from Primetime
    First, let me say I am not sure this functionality is possible, encounter is meant to work with its own STA engine. I am sure you can create the scripts yourself, but that would be a lot of work.
    Second, why are you using the ECO flow for? To fix timing? That is almost always a bad idea.
    Really, I am not Sam.
    •   AltAdvertisment
    Newbie level 3
    Jun 2018
    25
    It is sure that Industry uses PT as sign off tool and Physical Design Tool is Cadence Encounter /Innovus . So it is sure that there a method to take PT Script to innovus /encounter of cadence, I am not sure about the method, I am just asking anybody who has done this , please help
    •   AltAdvertisment
    Apr 2016
    1,544
    7,288
    20
    Check this link, it might be helpful. The guy is essentially doing ECO by hand http://tech.tdzire.com/timing-eco-flow-with-examples/
    Again, I think you should understand the goal of this exercise before going down the rabbit hole. PT works with ICC. Innovus works with Tempus. In the newer technology nodes you care a lot about convergence, leaving Innovus to do STA in PT is asking for trouble.
    Newbie level 3
    Jun 2018
    25
    It is understood that there is script which convert the PT Script for ECO Changes to Innovus Format . If anyone has it , please share .
