Results 1 to 2 of 2
    expertengr
    Removing previous posts and de activating account
    Is it possible to remove the previous posts and de activate account ?
    Points: 260,175, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,436
    260,175
    100
    Re: Removing previous posts and de activating account
    Deleting posts: generally no, see forum rules.
    Editing and Deleting Your Posts
    The administrators have decided to prevent users from deleting their own posts. In the past, deleting the first post of a thread would delete the entire thread, making it impossible for others to be able to read and learn from the information posted. There is also a limited amount of time in which you are allowed to edit your post, after that the post canít be edited.
    As a rule we do not remove or delete content from our forums so before you post consider this rule. If you donít want to share a schematic or code then donít post it but donít expect to get help and then delete your post, users in the forum spend valuable time in order to reply in your post so this info should remain available for users that may have a similar question in the future.
    Deactivating account, see
    https://www.edaboard.com/showthread....d-User-Account
