Results 1 to 6 of 6
    Newbie level 6
    Points: 1,000, Level: 7
    Apr 2013
    11
    1,000
    7
    Three Phase Pump controller_AN 984a
    I am working with three phase pump controller, with AN984a, dspic33fj12MC202, working very fine and delivering out put of 240AC phase to phase at 60Hz, Now I need to have 380AV or 415 AC phase to phase at 50Hz, and I am in need of support
    Points: 74,781, Level: 66
    Apr 2014
    15,167
    74,781
    66
    Re: Three Phase Pump controller_AN 984a
    Whatīs exactly the problem?
    * Increasing the power V_Bus voltage? --> show your power stage
    * decreasing the frequency? --> explained in the AN
    Points: 256,255, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,698
    256,255
    100
    To achieve 400 VAC phase-to-phase output voltage, you also need 400 VAC input and a power stage designed for 560 V DC link.
    Newbie level 6
    Apr 2013
    11
    1,000
    7
    hi
    Thank you, Even though bus bar voltage is 450V DC, corresponding output voltage is 240V AC at 60 Hz, I need at least 350V AC as out put phase to phase, what shall I do either in code or in the hard were
    I have checked even on 550V DC link but out put is 240V AC phase to phase, by varying the AN3 ratiometrically V & F changes max 240VAC at 60 Hz
    Apr 2014
    15,167
    74,781
    66
    I dont see the problem.
    Why? How do you come to this conclusion?
    --> Show what you have done so far and how you calculated the value.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,698
    256,255
    100
    Obviously, the voltage limitation is a problem of your software. You need to understand how the modulation index is calculated therein.
