[SOLVED] Code compilies with no errors but will not run at all
ghead
I've been having this same problem intermittently while writing/testing this code, Basically each routine/loop will run fine separately but when added all together code compiles with no warnings/errors but will not run. Currently when compiled and loaded into simulator this first instruction is "GOTO L0'' which is the location of the instruction so it can go no further. When enough or certain parts of the code are excluded then the remaining will run as expected but as soon as all parts are included it breaks. I've cut down RAM/ROM usage down to 19%RAM used and 35%ROM used. I've combed through and checked that i'm not causing an stack overflow as far as I can tell, I've tried not to call routines within any routines except within the main 'SWITCH' statements.
One thing i'm not to sure about is am I using 'SWITCH" in the wrong way causing this?
Am I not clearing variables that i need to?
Or is this a compiler thing?? (tried reinstalling a couple times and compiling other projects with no problems)
Basically i'm down to re configuring the whole program layout unless someone has some insight to where i'm going wrong?
Using PIC16F877A + LCD on PORTD
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
// LCD module connections //////////////////////////////////////////////////////
sbit LCD_RS at RD1_bit;
sbit LCD_EN at RD3_bit;
sbit LCD_D4 at RD4_bit;
sbit LCD_D5 at RD5_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D7 at RD7_bit;
sbit LCD_RS_Direction at TRISD1_bit;
sbit LCD_EN_Direction at TRISD3_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
// Output Pins /////////////////////////////////////////////////////////////////
sbit relay_non at RA0_bit;
sbit relay_inv at RA1_bit;
sbit out_heat at RA2_bit;
sbit out_cool at RA3_bit;
// Button Input Pins ///////////////////////////////////////////////////////////
sbit button_up at RB0_bit;
sbit button_down at RB1_bit;
sbit button_ok at RB2_bit;
// SPI pins ////////////////////////////////////////////////////////////////////
sbit spi_sck at RC3_bit;    //CLK
sbit spi_cs at RE2_bit;    //CS
sbit spi_si at RC4_bit;   //SDI
// Variables ///////////////////////////////////////////////////////////////////
bit a, horc, temp_direction;
unsigned int target_temp, act_target_temp, last_temp, overshoot;
short   b, bb, state, button_press_count;
unsigned char buffer, buffer0, buffer1, arrayFlow[7];
unsigned int current_temp, current_tmp1, target_temp1;
// Lcd Text ////////////////////////////////////////////////////////////////////
const char txt1[] = "TARGET:  ";
const char txt2[] = "ACTUAL:  ";
const char txt3[] = "OVERSHOOT:";
const char txt4[] = "TEMP";
const char txt5[] = "CONTROL";
const char txt6[] = "ERROR";
const char txt7[] = ">";
const char txt8[] = "<";
const char txt9[] = "C";
const char txt10[] = "Are You...";
const char txt11[] = "HEATING";
const char txt12[] = "COOLING";
const char txt15[] = "EDIT";
const char txt16[] = "00";
char msg[17]; //declare array set 16 bytes of RAM aside for copying into
// copy const to ram string
char * CopyConst2Ram(char * dest, const char * src){
  char * d ;
  d = dest;
  for(;*dest++ = *src++;)
  return d;
union U16_
   unsigned int word;      // For accessing the whole 16-bit unsigned int///////
   unsigned char byte[2];  // For accessing 16-bits as individual bytes/////////
void getcurrent_temp(){   //////;read the value from MAX6675///////////////////
     SSPCON.B5 = 1;        //Initialise SPI DEVICE
     spi_cs = 0;           //Start dummy read
     Delay_ms(2);
     spi_cs = 1;           //Start re-sample
     Delay_ms(220);        //should have new buffer
     spi_cs = 0;           //Start actual read
     Delay_ms(1);          //give the device time to settle
//     buffer1 = spi1_read(buffer); //fill buffer MSB's
//     buffer0 = spi1_read(buffer); //fill buffer LSB's
     buffer0 = 250;      //Dummy read 1
     buffer1 = 10;       //Dummy read 2
     buffer = 1;           //Not sure why this is needed??
     {                     //maybe needed for union??
     union U16_ Bytes2Int;
        Bytes2Int.byte[1] = buffer1;        //combine MSB's with LSB's
        Bytes2Int.byte[0] = buffer0;
        current_temp = Bytes2Int.word;     //combined bytes as a 16-bit word
     buffer = (buffer0 & 0x04);   //Mask off all but bit 2
     if (buffer  == 0x04 ) {current_temp = 999;} //bit_2 = 1 if thermocouple is not connected
     else {
        current_temp = current_temp >>3;   //remove flag values from read
        current_temp = current_temp *25;   //convert read to avoid decimal place
void eepromread(){// Read Target_temp & overshoot from eeprom and convert to int
     buffer0 = eeprom_read (0x00);
     buffer1 = eeprom_read (0x01);
     if (buffer0 == 0xff) {
        if (buffer1 == 0x0ff) {target_temp = 50;}
     else {
        Bytes2Int.byte[1] = buffer1;  //  combine bytes
        Bytes2Int.byte[0] = buffer0;  //
        target_temp = Bytes2Int.word; // return the combined bytes as a 16-bit word
     buffer0 = eeprom_read (0x10);
     buffer1 = eeprom_read (0x11);
     if (buffer0 == 0x0ff) {
        if (buffer1 == 0xff) {overshoot = 10;}
     else {
        overshoot = Bytes2Int.word; // return the combined bytes as a 16-bit word
     Delay_us(10);
void show_overshoot(){
     Lcd_cmd(_LCD_CLEAR);               //Clear display/////////////////////////
     Lcd_out (1,1,CopyConst2Ram(msg,txt3));                //Overshoot//////////
     IntToStr(overshoot, arrayFlow);    //convert overshoot value to display////
     Lcd_out(1,10,arrayFlow);           //display overshoot value///////////////
     Lcd_out (1,16,CopyConst2Ram(msg,txt9));               //C//////////////////
void show_target_temp(){
     Lcd_out (1,1,CopyConst2Ram(msg,txt1));                //Target Temp////////
     IntToStr(target_temp, arrayFlow);  //convert target value to display///////
     Lcd_out(1,10,arrayFlow);           //display target value//////////////////
void setout(){   //Turn on/off outputs
   if (horc = 1){
      relay_inv = 1;
      relay_non = 0;
   else {
      relay_inv = 0;
      relay_non = 1;
void unsetout(){  //Turn off/on outputs
   if (horc = 1){
      relay_inv = 0;
      relay_non = 1;
   else {
      relay_inv = 1;
      relay_non = 0;
void menustart(){      //starup menu decide between heating or cooling
     Lcd_Cmd(_LCD_CLEAR); // Clear display
     Lcd_Out(1,4,CopyConst2Ram(msg,txt10));   //ARE YOU...
     Delay_ms(2000);
     state = 0;
     bb = 1;
   while (bb){ //menu loop leave here when finshed//////////////////////////////
      switch (state){
         case 0:
            Lcd_Out (1,4,CopyConst2Ram(msg,txt7));
            Lcd_Out (1,5,CopyConst2Ram(msg,txt11));   // >>HEATING<<
            Lcd_Out (1,12,CopyConst2Ram(msg,txt8));
            Lcd_Out (2,5,CopyConst2Ram(msg,txt12));   //   COOLING
            if ((button_up == 0)||(button_down == 0)) {
               Delay_ms(50);
               while ((button_up == 0)||(button_down == 0)) {
                  Delay_ms (50); //;wait for the button to be released
               state = 1;
            if (button_ok == 0) {
               Delay_ms(50); //;debounce the button press
               while (button_ok == 0) {Delay_ms(50);}
               state = 2;
         break;
         case 1:
            Lcd_Out (1,5,CopyConst2Ram(msg,txt11));   //   HEATING
            Lcd_Out (2,4,CopyConst2Ram(msg,txt7));
            Lcd_Out (2,5,CopyConst2Ram(msg,txt12));   // >>COOLING<<
            Lcd_Out (2,12,CopyConst2Ram(msg,txt8));
               Delay_ms(50);
            state = 0;
            state = 3;
         break;
         case 2:
            Lcd_Out (1,3,CopyConst2Ram(msg,txt7));
            Lcd_Out (1,5,CopyConst2Ram(msg,txt11));   // ****HEATING****
            Lcd_Out (1,13,CopyConst2Ram(msg,txt8));
            horc = 0;
            out_cool = 0;
            out_heat = 1;
            bb = 0;
            Delay_ms(2000);
         break;
         case 3:
            Lcd_Out (2,3,CopyConst2Ram(msg,txt7));
            Lcd_Out (2,5,CopyConst2Ram(msg,txt12));   // ****COOLING****
            Lcd_Out (2,13,CopyConst2Ram(msg,txt8));
            horc = 1;
            out_heat = 0;
            out_cool = 1;
            bb = 0;
            Delay_ms(2000);
         break;
   unsetout();
void IntMain() {   //Prepare ports turn a/d off comparators off
     TRISA = 240;                 //PORTA led and relay outputs rest inputs
     TRISB = 255;                 //PORTB set button input pins
     TRISC = 255;                 //PORTC is spare set as Intputs
     TRISD =   0;                 //PORTD LCD
     TRISE =   2;                 //SPI CS = RE2
     OPTION_REG.B7 = 0;           //enable pullups on portb (RBPU)
     CVRCON =  0;                 //vref off
     CMCON =   7;                 //compartors off
     ADCON0 =  0;                 //a/d converter off
     ADCON1 =  6;                 //All Digital
     //Turn on SPI
     SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV16, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_HIGH_2_LOW);
     SSPCON.B5 = 1; //SPIPrepare_OSC / 16 = 1.25mhz clk_Sample data at MIDDLE_Clk idle Low_SPI receive on clk edge High to Low
     spi_cs = 1; //Set cs pin high  SPI device wait(sample)
     spi_sck = 0; //Set sck pin low SPI CLK idle
void main() {
     IntMain();                 //Initialise PORTS and Periphirals
     Lcd_init();                //Initialise LCD
     Lcd_Cmd(_LCD_CURSOR_OFF);  //no cursor on the lcd display
     Lcd_Out(1,7,CopyConst2Ram(msg,txt4));         //TEMP
     Lcd_Out(2,6,CopyConst2Ram(msg,txt5));         //CONTROL
     Delay_ms(2000);            //Delay for display
     menustart();               //select device attached heater or fan ??
     eepromread();              //Load target and overshoot from eeprom
     last_temp = 0;
     state = 0;
     temp_direction = 0;
   while(1){ //Main loop - Never leave here
      switch(state){ //Sub routine loop / switch
         case 0: //show the target and current temperature(s)
         getcurrent_temp();
         Lcd_out (1,1,CopyConst2Ram(msg,txt1));             //TARGET:
         Lcd_Chr_Cp(arrayFlow[3]);                          //100.00
         Lcd_Chr_Cp(arrayFlow[4]);                          //010.00
         Lcd_Chr_Cp(arrayFlow[5]);                          //001.00
         Lcd_Chr_Cp('.');                                   //000.00
         Lcd_out(1,14,CopyConst2Ram(msg,txt16));            //000.11
         Lcd_out(1,16,CopyConst2Ram(msg,txt9));             //      C
         Lcd_out(2,1,CopyConst2Ram(msg,txt2));              //ACTUAL:
         IntToStr(current_temp, arrayFlow);
         Lcd_Chr_Cp(arrayFlow[1]);
         Lcd_Chr_Cp(arrayFlow[2]);
         Lcd_Chr_Cp('.');
         Lcd_out (2,16,CopyConst2Ram(msg,txt9));             //      C
         Delay_ms(250);
         state = 1;
         break;
         case 1: //;monitor the current temp and the target temp
         state = 0;
         getcurrent_temp();
         current_tmp1 = current_temp / 100;
         if (horc = 0) {act_target_temp = target_temp - overshoot;}
         else act_target_temp = target_temp + overshoot;
         if (current_temp == 999) {    //Error code check
            unsetout();
            Lcd_out (2,3,CopyConst2Ram(msg,txt8));  // Display ***ERROR*** /////
            Lcd_out (2,4,CopyConst2Ram(msg,txt8));  // Display ***ERROR*** /////
            Lcd_out (2,5,CopyConst2Ram(msg,txt8));  // Display ***ERROR*** /////
            Lcd_out (2,6,CopyConst2Ram(msg,txt6));  // Display ***ERROR*** /////
            Lcd_out (2,11,CopyConst2Ram(msg,txt7));  // Display ***ERROR*** ////
            Lcd_out (2,12,CopyConst2Ram(msg,txt7));  // Display ***ERROR*** ////
            Lcd_out (2,13,CopyConst2Ram(msg,txt7));  // Display ***ERROR*** ////
         if (last_temp <= current_tmp1) {temp_direction = 1;}//temperature is rising
         else  temp_direction = 0;                           // else temperature is falling
         if (current_tmp1 > target_temp) {unsetout();}       //we're over the target temperature so shut the heaters off
         if (current_tmp1 > act_target_temp) {unsetout();}   //;threshold exceeded, turn off the heater(s)
         else setout();                                      //temperature is rising
         if (current_tmp1 < act_target_temp) {setout();}     //;weve cooled down, turn the heaters on again
         else unsetout();                                    //;were cooling down, but are still pretty close to the target
      /////while the temperature is being monitored, check for button presses///
         if ((button_up == 0)||(button_down == 0)||(button_ok == 0)) {
            unsetout();
            Delay_ms(50);
            while ((button_up == 0)||(button_down == 0)||(button_ok == 0)) {
               Delay_ms(50); //;wait f the button to be released
         state = 2;
         break;
         case 2: //;press buttons to change menu option/////////////////////////
         Lcd_cmd(_LCD_CLEAR);  //Clear display//////////////////////////////////
         Lcd_out (1,1,CopyConst2Ram(msg,txt1));    //Target:           /////////
         Lcd_out (1,10,CopyConst2Ram(msg,txt7));   //          >      //////////
         Lcd_out (1,12,CopyConst2Ram(msg,txt15));  //            Edit //////////
         Lcd_out (1,16,CopyConst2Ram(msg,txt8));   //                <//////////
         Lcd_out (2,1,CopyConst2Ram(msg,txt3));    //OVERSHOOT:       //////////
         Lcd_out (2,12,CopyConst2Ram(msg,txt15));  //            Edit //////////
         state = 3;
         break;
         case 3: //Decide which button is pressed
            Delay_ms(50);
               Delay_ms (50); //;wait f the button to be released
         state = 4;
            Delay_ms(50);
            a = 0;
            state = 6;
         break;
         case 4: //;press buttons to change menu option/////////////////////////
         Lcd_out (1,1,CopyConst2Ram(msg,txt1));   //TARGET:         ////////////
         Lcd_out (1,12,CopyConst2Ram(msg,txt8));  //           EDIT ////////////
         Lcd_out (2,1,CopyConst2Ram(msg,txt3));   //Overshoot:      ////////////
         Lcd_out (2,10,CopyConst2Ram(msg,txt7));  //          >     ////////////
         Lcd_out (2,12,CopyConst2Ram(msg,txt15)); //           EDIT ////////////
         Lcd_out (2,16,CopyConst2Ram(msg,txt8));  //               <////////////
         state = 5;
         break;
         case 5: //Is button up or down
            Delay_ms(50);
            state = 2;
            a = 1;
            state = 6;
         break;
         case 6: //;change the target and overshoot temperature value///////////
         if (a == 0) {
            show_target_temp();
            state = 7;
         if (a == 1) {
            show_overshoot();
            state = 7;
         break;
         case 7: //;button presses to alter target temperature/overshoot value//
         if (button_up == 0) {
            Delay_ms(50);
            button_press_count = 0;
            while (button_up == 0) {
               button_press_count = button_press_count + 1;
               Delay_ms(100);
               if (button_press_count >= 5) {
                  if (a == 0) {
                     if (target_temp < 500) { target_temp = target_temp + 10; }
                     else target_temp = 500;
                     show_target_temp();
                  else {
                     if (overshoot < 500) { overshoot = overshoot + 10; }
                     else overshoot = 500;
                     show_overshoot();
                  Delay_ms(200);
                  button_press_count = 5;  //;stop the counter from rolling over
               if (button_press_count < 5) {
                  if (a==0) {
                     if (target_temp < 500) {Target_temp = target_temp + 1;}
                     show_target_temp();
                  if (a==1) {
                     if (overshoot < 500) {overshoot = overshoot + 1;}
                     show_overshoot();
            state = 7;
         if (button_down == 0) {
            Delay_ms(50);
            while (button_down == 0) {
               Delay_ms(100);
                  if (a == 0) {
                     if (target_temp > 10) { target_temp = target_temp - 10; }
                     else target_temp = 0;
                     show_target_temp();
                  else {
                     if (overshoot > 10) { overshoot = overshoot - 10; }
                     else overshoot = 0;
                     show_overshoot();
                  Delay_ms(200);
                  if (a==0) {
                     if (target_temp > 1) {Target_temp = target_temp - 1;}
                     show_target_temp();
                  if (a==1) {
                     if (overshoot > 1) {overshoot = overshoot - 1;}
                     else overshoot = 0;
                     show_overshoot();
            state = 7;
            Delay_ms(50); //;simple debounce
            while (button_ok == 0) {Delay_ms(50);} //;wait for button to be released
            if (a == 0) {
                  union U16_ Int2Bytes;
                  Int2Bytes.word = target_temp;
                  eeprom_write (0x01,Int2Bytes.byte[1]);  // write the hi byte
                  eeprom_write (0x00,Int2Bytes.byte[0]);  // write the lo byte to eeprom
            if (a == 1) {
                  Int2Bytes.word = overshoot;
                  eeprom_write (0x11,Int2Bytes.byte[1]);  // write the hi byte
                  eeprom_write (0x10,Int2Bytes.byte[0]);  // write the lo byte to eeprom
            state = 0;
         break;
////////////////////////////////PROGRAM END/////////////////////////////////////
Example: Here I've commented out main loop and code will run as expected and hang when it gets to main while loop as expected and inversley if other parts are commented out then main etc loop runs fine.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
  char * d ;
  d = dest;
  return d;
union U16_
     Delay_ms(2);
     else {
     else {
     else {
     Delay_us(10);
   if (horc = 1){
      relay_inv = 1;
      relay_non = 0;
   else {
      relay_inv = 0;
      relay_non = 1;
   if (horc = 1){
      relay_inv = 0;
      relay_non = 1;
   else {
      relay_inv = 1;
      relay_non = 0;
     Delay_ms(2000);
     state = 0;
     bb = 1;
      switch (state){
         case 0:
               Delay_ms(50);
               state = 1;
               state = 2;
         break;
         case 1:
               Delay_ms(50);
            state = 0;
            state = 3;
         break;
         case 2:
            horc = 0;
            out_cool = 0;
            out_heat = 1;
            bb = 0;
            Delay_ms(2000);
         break;
         case 3:
            horc = 1;
            out_heat = 0;
            out_cool = 1;
            bb = 0;
            Delay_ms(2000);
         break;
   unsetout();
     //Turn on SPI
void main() {
     last_temp = 0;
     state = 0;
     temp_direction = 0;
/*      switch(state){ //Sub routine loop / switch
         getcurrent_temp();
         Lcd_Chr_Cp('.');
         Delay_ms(250);
         state = 1;
         break;
         state = 0;
         getcurrent_temp();
            unsetout();
            unsetout();
            Delay_ms(50);
         state = 2;
         break;
         state = 3;
         break;
            Delay_ms(50);
         state = 4;
            Delay_ms(50);
            a = 0;
            state = 6;
         break;
         state = 5;
         break;
            Delay_ms(50);
            state = 2;
            a = 1;
            state = 6;
         break;
         if (a == 0) {
            show_target_temp();
            state = 7;
         if (a == 1) {
            show_overshoot();
            state = 7;
         break;
            Delay_ms(50);
               Delay_ms(100);
                  if (a == 0) {
                     show_target_temp();
                  else {
                     show_overshoot();
                  Delay_ms(200);
                  if (a==0) {
                     show_target_temp();
                  if (a==1) {
                     show_overshoot();
            state = 7;
            Delay_ms(50);
               Delay_ms(100);
                  if (a == 0) {
                     show_target_temp();
                  else {
                     else overshoot = 0;
                     show_overshoot();
                  Delay_ms(200);
                  if (a==0) {
                     show_target_temp();
                  if (a==1) {
                     else overshoot = 0;
                     show_overshoot();
            state = 7;
            if (a == 0) {
            if (a == 1) {
            state = 0;
         break;
Looking on your code only thing I can recommend is start doing more practice. It is just too earlier for you to keep trying develop somethig. Code is very poor. I can't spend so much time to make it working.
I am aware of how poor it is as i'm still new at learning c. Any simple pointers would help as this is practice/learning, May have jumped in the deep end with this project but its so close to give up now.
It was not clear how you proceeded to do this simulation, nor what simulator have you used. If it was Proteus, make sure that the compilation was done from within ISIS itself, ie that the HEX file has not been externally compiled and imported afterwards. In other words, importing an externally compiled file would work, but you would not be able to debug through the Source Code window anymore.
Several places this is wrong
 if (horc = 1){
      relay_inv = 1;
      relay_non = 0;
   else {
      relay_inv = 0;
      relay_non = 1;
The "=" in place of "==".
Reactions: ghead
    ghead
I should have included that info. I compiled it in mikroc pro and loaded hex into pic simulator ide and disassembled it to view where and what instruction was causing it to fail.
That's the right way. But you either need to understand yourself why this happens or report the results in a reproduceable form.
Reactions: ghead
    ghead
So turns out some files were corrupted (hdd is failing apparently), After reinstalling Mikroc and rebooting, chkdsk popped up and 2 hrs later.. Fixed!!!! Program runs exactly as expected, weird how other projects compiled fine and ran, But then I never moved source files etc so was probably my current project written on some bad sectors is all I can come up with Thank you all for your sage advice . Attached in project folder for anyone interested tho MCU is pretty much obsolete the code should be easily ported to another MCU.
Heres my:
Temperature controller / sensor for heating or cooling using PIC16F877A and MAX6675 + cold junction thermocouple and 16X2 LCD
