[ARM] LPC2136 interrupt not working UART0 __irq
rtoribio
Newbie level 2
hello freinds,
I am using LPC2136 on MDK-lite v-5.25 with legacy pluggins to run ARM7TDMI, but i dont know why this code is not working with interrupt on UART0 __irq this can not TX0 and RX0.
here all my funtions and codes:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
#include "LPC213X.h"
#include <stdint.h>
#include "ST7735.h"
extern void initPLL(void);
extern void SPI_init(void);
extern void Serial0_init(void);
extern const uint16_t Logo[];                       //Imagen logo utesa.
extern void UART0_Interrupt_EN(void);
extern void init_gpiox(void);
__irq void UART0Handler (void);
void delay(void);
char rxdat;
int main(void)
    int x, y, dx, dy;
    init_PLL();
    SPI_init();
    Serial0_init();
    init_gpiox();
    UART0_Interrupt_EN();
    while(1);
    U0THR= 'A';
    U0THR= 'B';
    IO0SET |= 0x00000080;
    delay();
    IO0CLR |= 0x00000080;
    ST7735_FillScreen(0xFFFF);            // set screen to white
  x = 15; //44
  y = 130; //159
  dx = 1;
  dy = 0;
  while(1){
        //ST7735_DrawBitmap(x, y, Logo, 40, 160);
    ST7735_DrawBitmap(x, y, Logo, 96, 96);
    x = x + dx;
    y = y + dy;
    if((x >= (ST7735_TFTWIDTH - 40 + 15)) || (x <= -15)){
      dx = -1*dx;
    if((y >= (ST7735_TFTHEIGHT + 8)) || (y <= (ST7735_TFTHEIGHT - 8))){
      dy = -1*dy;
//  while(1);
    rxdat = U0RBR;
        VICVectAddr= 0x00000000;
        delay();
void delay(void)
    uint32_t i;
    for(i=0;i<=320000;i++);
    PINSEL0=0x00050000;             //Habilitar TDX0 RDX0.
    U0FCR=0x01;
    U0LCR=0x00000083;                   //8bits, no paridad y bit de stop.
    U0DLL=85;                                       //Velocidad de puerto serial 9600 baudios.
    U0DLM=0x0;
    U0FDR= 0x0000005E;              //  MULVAL = 0x5 and DIVADDVAL = 14
    U0LCR= 0x00000003;              //DLAB = 0.
    U0IER= 0x00000003;              //Interrupciones habilitadas en el puerto serial 0.
extern __irq void UART0Handler (void);
    VICIntSelect = 0x00000000;
    VICVectAddr0 = (unsigned int) UART0Handler;             //Vector 0 para la interrupcion serial
    VICVectCntl0 = 0x26;                        //select UART0 interrupt as IRQ i.e vector 0
    VICIntEnable = 0x00000040;
Sorry that was in my last test i didnt remove it.
#include <stdint.h>
#include "ST7735.h"
void delay(void);
char rxdat;
int main(void)
	int x, y, dx, dy;
	init_PLL();
	SPI_init();
	Serial0_init();
	init_gpiox();
	while(!(U0LSR&0x20));                 //THRE = 0 stay here
	U0THR= 'R';
	U0THR= 'A';
	U0THR= 'U';
	U0THR= 'L';
	while(1);
	U0THR= 'B';
	delay();
  x = 15; //44
  y = 130; //159
  dx = 1;
  dy = 0;
  while(1){
    x = x + dx;
    y = y + dy;
      dx = -1*dx;
      dy = -1*dy;
//	while(1);
void UART0Handler (void)  __irq
		while(!(U0LSR & 0x01));                        //RDR = 0 stay here
    rxdat = U0RBR;
		delay();
void delay(void)
	uint32_t i;
My problem is when i try to recieved data from  (rxdat = U0RBR;) is not jumping to the _irq funtion:
is not working
    rxdat = U0RBR;
		delay();
What i am seeing is infinite loop in the irq function. Generally you should never be in an infinite loop in an interrupt function.
