Applying KVL on an NPN BJT.
Jayce
Newbie level 5
From the figure above. On the book I'm reading, KVL was applied from around the base-emitter circuit. (From Vee rotating clockwise.) The equation resulted to:
Vee + Ib*Rb + Vbe + IeRe = 0.
But looking at the placement of the battery, shouldn't it be: Vee - Ib*Rb - Vbe - IeRe = 0?
Note: The book follows conventional current for the flow.
Perhaps part of the question is to realize that the answer could be Vee as having negative value, apart of its orientation drawn on the circuit.
No - it is correct. The current is considered as to flow from the positive to the negative end of the resistors, the B-E junction and the voltage source.
Just place the voltage arrows across each element to see the equation
is wrong. Doesn't matter the numerical value of voltage and current. The result is symbolic and take into account the choosen polarities.
