Results 1 to 2 of 2
    Member level 5
    Points: 1,024, Level: 7
    Mar 2015
    93
    1,024
    7
    Radiation Pattern Check
    Can someone please check my radiation pattern for a multiband coaxial fed patch antenna and tell me if they are fine. If not, what should be the improvements?
ID:	146699Click image for larger version.
ID:	146701Click image for larger version.
ID:	146703Click image for larger version.
    Urgent help needed !!!
    Thanks in advance :)
    •   AltAdvertisment
    Member level 5
    Mar 2015
    93
    1,024
    7
    Re: Radiation Pattern Check
    1. Is it necessary that the radiation pattern be observed at phi=0 and phi=90 only ?
    2. Is it fine to have a negative gain at phi=0 and positive at phi=90 ?
    3. Is there a particular pattern to be observed ?
    4. Should we check gain or directivity ?
