Results 1 to 9 of 9
    Points: 274, Level: 3
    Dec 2017
    48
    274
    I need help identifying these diodes
    Hello everyone,
    I have a bunch of diodes of the SMD type packaged in tape and I believe they are more than 500. As far as I remember, they were ordered by a mistake so I put them aside. They were kept in an anti-static plastic bag without any markings, PNs, or anything else that could help in identifying them.
    As you can see in the following photos, they look like a Schottky or normal signal diode and the voltage drop across it is 0.550V.
    Now, I was wondering if I can use this type of diode in a full-wave bridge rectifier circuit to rectify 220V mains. This way, I can utilize them for something useful.
ID:	146680Click image for larger version.
    Thanks in advance!
    Points: 20,551, Level: 34
    barry's Avatar
    Mar 2005
    California, USA
    3,963
    20,551
    34
    Re: I need help identifying these diodes
    Those are little, black, cylindrical diodes.
    You can't seriously expect anybody to tell you anything more about those. Maybe they are red LEDs.
    •   Alt16th May 2018, 22:14
      advertising
    Points: 70,960, Level: 65
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    11,626
    70,960
    65
    They are MELF packaged but the only other identifying characteristic is the color of the cathode band. If it is silver it is probably an LL4007 which is a standard recovery diode rated at 1KV/1A. I have identical ones here. Use at you own risk though, there might be other devices with the same marking.
    Full Member level 3
    Points: 1,300, Level: 8
    Relayer's Avatar
    Jul 2016
    Werribee, Australia
    161
    1,300
    8
    Hello e-music,
    Schottky diodes normally have a lower voltage drop across them to what you've indicated.
    I think Brian is correct in regards to them being general purpose rectifying types.
    If you can, get a transformer with a low secondary output and make a full bridge rectifier
    circuit and see how the diodes will tolerate it over time.
    Connecting them directly to mains I would personally avoid, due to the fact that if they are
    the Schottky type, I doubt they could withstand the peak reverse voltages generated by
    direct AC mains connection. They would still work OK at lower AC voltage, but they will
    heat up more than GP type diodes, as well as introduce extra noise due to their faster
    switching speeds.
    They definitely don't look like small signal diodes, and very doubtful they will be Zeners.
    Regards,
    Relayer
    •   Alt17th May 2018, 01:16
      advertising
    Points: 13,455, Level: 27
    schmitt trigger's Avatar
    Apr 2013
    C4E4DEEEDCE6ECD2
    2,261
    13,455
    27
    Only way to really tell, is if you have access to a curve tracer.
    That way, at least you can determine Vf and Vbr.
    Since there is no way that you could measure recovery time, I would not use them other than low frequency AC rectification.
    My batteries are recharged by "Helpful Post" ratings.
    Dec 2017
    48
    274
    Quote Originally Posted by barry View Post
    Red LEDs? Well, it could be difficult to identify them, but I'm pretty sure they are anything but "Red LEDs"! I have never seen a Red LED without a lens and packaged in such a way! :))
    Anyways, thanks for the info!
    @Brian:
    Thank you. Yes, the band is in silver.
    @Relayer:
    Hi Relayer,
    Thank you very much for the input. A detailed and very helpful one, as usual!
    Yes, and I believe they are GP rectifiers, too. I believe the only way to verify is to build a full-wave bridge and check them in circuit for some time. I'm working on a project that needs power directly off the mains and a Transformer-less PS is the only way for me to keep size and cost low for the board. I thought I could use them for the bridge-rectifier and save a little. Otherwise, a bridge rectifier in a single package is much better.
    Thanks again!
    @schmitt trigger:
    Thank you for your reply. Yes, I had that in mind initially. I wanted to use them in a bridge rectifier configuration to rectify 220v/50Hz mains.
  7. #7
    barry's Avatar
    Mar 2005
    California, USA
    3,963
    20,551
    34
    Well, it was laying on a schematic right next to a component that said "LED red".
    But, seriously, I would hesitate to hook up an unknown component to 220V. Just go buy four 500V rectifiers; they're about $0.10 each.
  8. #8
    Dec 2017
    48
    274
    @ barry:
    In fact, it's about 700 of them, not four. And I need to populate a big batch of boards I plan to build with these diodes. Nevertheless, I agree with you. Even $70 is not a big deal to order the correct diodes for my circuit.
    By the way, the schematic in the photo has nothing to do with this circuit or the diode concerned!
    Thank you again for your reply!
    •   Alt18th May 2018, 16:25
      advertising
  9. #9
    barry's Avatar
    Mar 2005
    California, USA
    3,963
    20,551
    34
    Quote Originally Posted by e-music View Post
    @ barry:
    I am just astounded. You are apparently building something to actually sell to customers, and you seriously considered building them out of parts that you DON'T KNOW WHAT THEY ARE? I hope you have good liability insurance.
