Results 1 to 11 of 11
    Points: 387, Level: 4
    Mar 2018
    53
    387
    reducing number of interconnections in a circuit
    I have a design which consists of 7 sets of push wheel switches, each set with 4 digit. The digital parallel outputs from these switches amounts to 16 X 7!
    Is there a way to minimize wiring requirements. I was thinking of a serial shift register. Any ideas?
    •   AltAdvertisment
    Points: 21,710, Level: 35
    barry's Avatar
    Mar 2005
    California, USA
    4,162
    21,710
    35
    Re: reducing number of interconnections in a circuit
    Not sure what your switches look like. Isn't each digit four outputs and one common? If so, you could tie the four outputs of each digit together (i.e., 1 to 1, 2 to 2) then you would just need 28 commons and 4 outputs. You could further reduce the wires by using a 5:32 decoder to drive the commons==>9 wires.
    Points: 64,830, Level: 62
    Apr 2014
    13,161
    64,830
    62
    Calculating the minimum lines with simple multiplexing technology:
    16 × 7 = 112 lines
    Sqrt(112) = something with 10.x
    This means 11 + 11 = 22 signal lines.
    The absolute minimum is a 7 to 128 decoder --> 7 outputs + 1 input = 8 lines.
    Or a 6 to 64 with 2 inputs.
    In either case you need 112 diodes to combine the signals.
    For sure one can think of some more intelligent solutions:
    * dedicated multiplexing IC similar to those in PC keyboards.
    * or a solution with resistors and ADC...
    In the end Barry's solution (but with the diodes) maybe is the most useful.
    barry's Avatar
    Mar 2005
    California, USA
    4,162
    21,710
    35
    Diodes? What diodes? All you need is to drive each of 28 commons individually and wire-or the four BCD outputs of each digit. (This presumes the undriven commons float.)
    But a 112-bit shift register would be the absolute minimum wire count: Latch clock, data. You could do this in a CPLD.
    •   AltAdvertisment
    Apr 2014
    13,161
    64,830
    62
    I assume without diodes it won´t work:
    Two BCD switches. Each with 4 outputs
    Now assume the left one shows "0x1" and the right one "0xF".
    Obviously the right one shorts all the BCD lines independent if it´s COM is selected or not.
    --> if COM1 is selected, all BCD outputs are acitve, instead of only line "1".
    •   AltAdvertisment
    barry's Avatar
    Mar 2005
    California, USA
    4,162
    21,710
    35
    Ahhhhh, you're right. I shouldn't post so early or so late in the day... I was thinking more in terms of how we multiplex LED displays. Not the same.
    This is making the shift-register approach a little more appealing. Could probably do this in a US$15 CPLD (rather than seven 16-bit SRs.)
  7. #7
    Points: 247,256, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,987
    247,256
    100
    Surely possible but uncomfortable pin count. I would prefer 14*74HC165 as a first approach, about 3 $.
  8. #8
    barry's Avatar
    Mar 2005
    California, USA
    4,162
    21,710
    35
    144 pin CPLD has 80 fewer pins than fourteen 16-pin devices. And less board space. But this is all kind of academic without knowing what the OPs intent is. Is this a high-production design? A hobby thing?
  9. #9
    Points: 27,654, Level: 40
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,253
    27,654
    40
    Blog Entries
    The question at all does not provide enough information to evaluate the suited solution. Depending on the distance, the wirings, the Vdd power level, and the change rate of the switches status, this can limit the implementation of some solutions. In particular, whenever possible I prefer the solution based on parallel input type 74xx373, once with this approach it is possible to repeat the reading in only one clock cycle, just to confirm the correctness of the previous reading.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
  10. #10
    Apr 2014
    13,161
    64,830
    62
    Hi
    Some ideas:
    one could use multiple diodes in one package: like 8 diodes with common cathode: "D92C" from BI technologies.
    One could ask: why that much BCD switches. When we have microcontrollers and rotary encoder switches.
    One could make an IC per set (4 BCD switches). Then one has 7 identical devices connected vie I2C. Maybe something like PCF8547..
    •   AltAdvertisment
  11. #11
    Mar 2018
    53
    387
    Hi
    Thanks to everyone for giving excellent insight into this problem. Push wheel switches are passive and non volatile . In my application, I am prohibited to use memory devices. Now I have to decide between 373 vs shift register approach. 373 would add 16 outputs+ 7 enable signals. Shift register if cascaded as long shift register would take only 1 output (SO)+1 clk+1shift/ld ( common to 7 SR's)
