Results 1 to 15 of 15
    Newbie level 6
    Points: 10, Level: 1
    Mar 2018
    14
    10
    this code for interfacing ADC 122S101 is not working
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    module adc_12b(clk,d_in,d_out,sclk,cs);
     input clk;     //,reset;
     input d_in;
     output [11:0] d_out;
     output sclk,cs;
     reg cs;
     reg [11:0] temp;
     reg [1:0] state=2'b00, nxt_state;
     reg [4:0] count,count1;
     reg [11:0] dout;
     assign sclk=clk;
     parameter idle=2'b00, read=2'b01;
    // always@(posedge clk)
    //   begin
    //       if(reset)
    //       state=idle;
    //       else
    //       state=nxt_state;
    //   end
         begin
    //       if(reset)
    //       count<=0;
    //       else
             if(count>=5'd16)
             count<=0;
             else if(state==idle)
             begin
             count<=0;
             count<=count+1;
             end
             else
             count<=0;
         end
         begin
    //       if(reset)
    //       count1<=0;
    //       else
             if(count1>=5'd16)
             count1<=0;
             else if(state==read)
             count1<=count1+1;
             else
             count1<=0;
         end
     always @(negedge clk)
         begin
             case(state)
             idle:begin
             if (count==5'd16)
                 begin
                 nxt_state <= read;
                 cs <= 1'd0;
                 end
             else
                 begin
                 nxt_state <= idle;
                 cs <= 1'd1;
                 end
             end
            read:begin
           if(count1<=5'd16)
                begin
                temp[0] <= d_in;
                 temp[1] <= temp[0];
                 temp[2] <= temp[1];
                 temp[3] <= temp[2];
                 temp[4] <= temp[3];
                 temp[5] <= temp[4];
                 temp[6] <= temp[5];
                 temp[7] <= temp[6];
                 temp[8] <= temp[7];
                 temp[9] <= temp[8];
                 temp[10] <= temp[9];
                 temp[11] <= temp[10];
                 nxt_state <= read;
                 end
            else
                 begin
                 nxt_state <= idle;
                 dout<=temp;
                 end
            end
        endcase
     end
     assign d_out=dout;
     endmodule
    the timing diagram is as below
    Points: 250,714, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    43,647
    250,714
    100
    Re: this code for interfacing ADC 122S101 is not working
    Why not write a test bench and simulate the module?
    You are reading din at a reduced clock rate but operating sclk still at full rate. That can't work. You probably forgot to generate an appropriate sclk.
    Points: 29,773, Level: 42
    ads-ee's Avatar
    Sep 2013
    USA
    6,857
    29,773
    42
    Really you commented out the reset!?
    Why?
    FvM's suggestion to run a simulation will yield useless results as there will be X's everywhere as the FSM has no information on where to start.
    •   AltAdvertisment
    Newbie level 6
    Mar 2018
    14
    10
    Quote Originally Posted by ads-ee View Post
    Why?
    Could you please help me in sorting out this issue?
    Newbie level 6
    Mar 2018
    14
    10
    how to increase the clock rate simmilar to that of sclk???
    Advanced Member level 3
    Points: 5,707, Level: 17
    Feb 2015
    942
    5,707
    17
    state is used but never assigned (after initialization).
    --edit: The tragedy is that the problem nets would be among the few not shown as X!
    •   AltAdvertisment
  7. #7
    Full Member level 5
    Points: 2,068, Level: 10
    Nov 2013
    Germany
    268
    2,068
    10
    Quote Originally Posted by adhul View Post
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
     input d_in;
     output sclk,cs;
     reg cs;
     reg [11:0] temp;
     reg [11:0] dout;
     assign sclk=clk;
    //   begin
    //       if(reset)
    //       state=idle;
    //       else
    //       state=nxt_state;
    //   end
         begin
    //       if(reset)
    //       count<=0;
    //       else
             if(count>=5'd16)
             count<=0;
             begin
             count<=0;
             count<=count+1;
             end
             else
             count<=0;
         end
         begin
    //       if(reset)
    //       count1<=0;
    //       else
             if(count1>=5'd16)
             count1<=0;
             count1<=count1+1;
             else
             count1<=0;
         end
         begin
             case(state)
             idle:begin
             if (count==5'd16)
                 begin
                 nxt_state <= read;
                 cs <= 1'd0;
                 end
             else
                 begin
                 nxt_state <= idle;
                 cs <= 1'd1;
                 end
             end
            read:begin
           if(count1<=5'd16)
                begin
                temp[0] <= d_in;
                 temp[1] <= temp[0];
                 temp[2] <= temp[1];
                 temp[3] <= temp[2];
                 temp[4] <= temp[3];
                 temp[5] <= temp[4];
                 temp[6] <= temp[5];
                 temp[7] <= temp[6];
                 temp[8] <= temp[7];
                 temp[9] <= temp[8];
                 nxt_state <= read;
                 end
            else
                 begin
                 nxt_state <= idle;
                 dout<=temp;
                 end
            end
        endcase
     end
     assign d_out=dout;
     endmodule
    I suggest you do not use nxt_state and assign the state signal to idle or read parameters. If you are planning to then u need to define it properly so that it shifts from state to nxt_state or you can simply write state instead of nxt_state.
    1. Instead of using nxt_state use state = idle/read in your code above.
    2. You also need to assign if(count1<5'd16) to get your temp value assigned to dout otherwise you do not get any output.
    As the other guys mentioned use a test bench to fine tune your code. You just need 2 input signals in your test bench. Are you sure that the din input is just 1 bit?
    Why?
    Reset is commented because for the obvious reason that its not at all used in the module. It should work without reset.
    •   AltAdvertisment
  8. #8
    Newbie level 6
    Mar 2018
    14
    10
    thank you sir.. the code get synthesized.. but when i tried to put it on spartan 6 and the output was observed by varying the potentiometer the last msb bits are not coming and also if the input voltage to the ADC is 3.3V then by 1.7V the 10 leds glows,which means the output is wrong . what the error can be??
    i have been doing that but nothing is happening my way..
    The code is attached below
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    module adc_new1(clk,d_in,,ch,d_out,sclk,cs);
     input clk;
     input d_in;
     output ch;
     output [15:0] d_out;
     output sclk,cs;
     wire cs;
     reg [15:0] temp;
     reg [1:0] state=2'b00;
     reg [4:0] count=0;
     reg [4:0]count1=0;
     reg [15:0] dout;
     reg ch=0;
     assign sclk=clk;
     assign cs = 1'd0;
    //   begin
    //       if(reset)
    //       state=idle;
    //       else
    //       state=nxt_state;
    //   end
         begin
    //       if(reset)
    //       count<=0;
    //       else
             if(count>5'd3)
             count<=0;
             begin
             //count<=0;
             count<=count+1;
             end
             else
             count<=0;
         end
         begin
    //       if(reset)
    //       count1<=0;
    //       else
             if(count1>5'd15)
             count1<=0;
             count1<=count1+1;
             else
             count1<=0;
         end
     always @(posedge clk)
         begin
             case(state)
             idle:begin
             if (count==5'd15)
                 begin
                 state <= read;
                 //cs <= 1'd0;
                 end
             else
                 begin
                 state <= idle;
                 //cs <= 1'd1;
                 end
             end
            read:begin
           if(count1<=5'd15)
                begin
                temp[0] <= d_in;
                 temp[1] <= temp[0];
                 temp[2] <= temp[1];
                 temp[3] <= temp[2];
                 temp[4] <= temp[3];
                 temp[5] <= temp[4];
                 temp[6] <= temp[5];
                 temp[7] <= temp[6];
                 temp[8] <= temp[7];
                 temp[9] <= temp[8];
                     temp[12] <= temp[11];
                     temp[13] <= temp[12];
                     temp[14] <= temp[13];
                     temp[15] <= temp[14];
                 state <= read;
                 end
            else
                 begin
                 state <= idle;
                 dout<=temp;
                 end
            end
        endcase
     end
     assign d_out=dout;
     endmodule
    Last edited by BradtheRad; 31st May 2018 at 03:12. Reason: Added code formatted window
  9. #9
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    43,647
    250,714
    100
    CS is not operated in the latest code, can't work.
    Additional points, you never mentioned the clock frequency driving your design. Consider that ADC122S101 must keep an SCLK range of 8 to 16 MHz. I see that you have been playing around with clock edges. It's correct to read DOUT at the rising edge of SCLK, to comply with the datasheet specification, CS (and also DIN, if utilized) must be set at the falling SCLK edge.
    The best way to achieve it is to clock the design at double SCLK frequency and toggle SCLK in your design.
  10. #10
    Newbie level 6
    Mar 2018
    14
    10
    K
    Sir,
    Sorry i put the wrong code this was the code
     input clk;
     input d_in;
     output ch;
     output sclk,cs;
     reg cs;
     reg [11:0] temp;
     reg [4:0] count=0,count1=0;
     reg [11:0] dout;
     reg ch=0;
     assign sclk=clk;
    //   begin
    //       if(reset)
    //       state=idle;
    //       else
    //       state=nxt_state;
    //   end
         begin
    //       if(reset)
    //       count<=0;
    //       else
             if(count>=5'd16)
             count<=0;
             begin
             count<=0;
             count<=count+1;
             end
             else
             count<=0;
         end
         begin
    //       if(reset)
    //       count1<=0;
    //       else
             if(count1>=5'd16)
             count1<=0;
             count1<=count1+1;
             else
             count1<=0;
         end
         begin
             case(state)
             idle:begin
             if (count==5'd16)
                 begin
                 state <= read;
                 cs <= 1'd0;
                 end
             else
                 begin
                 state <= idle;
                 cs <= 1'd1;
                 end
             end
            read:begin
           if(count1<5'd16)
                begin
                temp[0] <= d_in;
                 temp[1] <= temp[0];
                 temp[2] <= temp[1];
                 temp[3] <= temp[2];
                 temp[4] <= temp[3];
                 temp[5] <= temp[4];
                 temp[6] <= temp[5];
                 temp[7] <= temp[6];
                 temp[8] <= temp[7];
                 temp[9] <= temp[8];
                 state <= read;
                 end
            else
                 begin
                 state <= idle;
                 dout<=temp;
                 end
            end
        endcase
     end
     assign d_out=dout;
     endmodule
  11. #11
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    43,647
    250,714
    100
    Now reading d_in at the wrong SCLK edge.
  12. #12
    Newbie level 6
    Mar 2018
    14
    10
    "The best way to achieve it is to clock the design at double SCLK frequency and toggle SCLK in your design."
    how to code this ???
  13. #13
    Full Member level 5
    Nov 2013
    Germany
    268
    2,068
    10
    Can you tell the clk and sclk value? In the pic share above in your first post, is the waveform of your clk and sclk signal the same? There is missing information of your clk in the timing diagram, can you repost the timing diagram with clk signal in it?
  14. #14
    Newbie level 6
    Mar 2018
    14
    10
    thanks for you reply.
    In the timing diagram also they didnt mentioned about the clock frequency.
    i assumed it to be the same and followed the remaining.
    i got the output also. initially i put the frequency as 20 MHz but some bits was missing but later i changed to frequency of about 4 MHz. So i got the output.
    •   AltAdvertisment
  15. #15
    Points: 68,591, Level: 63
    Apr 2014
    14,003
    68,591
    63
    clk: is only in the FPGA, thus it is not meantioned in the datasheet
    sclk: for sure is specified in the datasheet: 8MHz <= F_sclk <= 16MHz.
    --> 20MHz is out of specification.
    Please read the datsheet.
